Gearbox and diff oil
germ
Post by germ »
well erm today i finally got round to changing my gearbox and diff oil...............
OMG!!! WoW :!: :!: :arrow: its soooo amazing the differnce the gears go in super smooth and fast,its quiter, the car feels much faster.
i put fully synthetic racing oil in the gearbox (automatic,and manual) gearbox oil, the red stuff. and 80w somthing semi synthetic diff oil in the diff.
no really no jokes the differnce is amazing, the oil was believed to never of been changed just topped up. - i think this was the best 52 euros i ever spent.
Just thought i would share that with you :lol:
will
Volvo 340 Image 1988
ajdubas
Post by ajdubas »
52 euros? that's well expensive :P
I reckon I could do it for... £15 which is about 23 euros.
germ
Post by germ »
yup its very expensive to me too, but there wasnt much choice, that and i had to buy it in 1 liter containers :roll: ,
iam going to change it again when i get back to england :twisted:
seriously its a delight to drive and i want it to stay that way. :P
will
Ronnie
Post by Ronnie »
I thought that diff needed ATF or bad things would happen?
http://www.filterfeeder.eu
Vart
Post by Vart »
The gearbox needs ATF, the diff claims to need 90 although i found only 80w90 is easily obtainably. i ended up getting a gallon on ATF and a couple of litres of 80w90 "heavy gear oil" when Mac and I changed my 340 to a 5 speed. must of cost around £25 for the oil.
Yup, ATF in manual gearboxes and manual gearbox oil in CVTs ;) Make sure its the friction modified stuff though, so none of that ATF-F, you want a Dexron type, or if you can still get it, ATF A/A :)
shimon340
Post by shimon340 »
hi,
from the posts here seems the gearbox oil spec causes some problems with local motor factors.
both castrol and commas own tech specs advise that 10W40 is used in the gearbox... cant be right.
the green books for the early (1980s) cars advises ATF type F or G. The later owners manual advises the same ATF type F but has a note of increased capacity for the 5 speed.
Ive found comma ATF TQF locally which another post here says isnt applicable.
Anyone know of a brand of ATF Type F? doesnt seem comma makes it.
ATF A/A is friction modified whilst ATF type F isnt.
cant seem to find Type F locally at the moment...
anyone know of a brand?
Enjoy your 300s
Fuse
Post by Fuse »
Type F is more rare, because it's an oil which some old Ford boxes use so not too common. ;) Shell Donax line has type-f oil. It's called Shell Donax TF.
Also Mobil 210 is type-f oil.
dalahare
Post by dalahare »
Just made up a new gasket for the diff and refilled it with 85w140 diff oil. :lol:
Much smoother and the oil doesn't splatter all over the car now when out on the highway. 8)
The ATF spec you're quoting is for different gearboxes, the M45R and M47R units fitted to 300s are different and all use ATF type A/A, the closest modern equivalent is Dexron, a friction modified oil.
ATF F is a non-friction modified oil.If you put in ATF/F then I don't know what would happen but I guess it wouldn't be too good.
The advice from Castrol is passed down from Volvo. They now advise that 10w-40 engine oil is used rather than any sort of ATF, that goes for the M45/46/47 found in 2/7/9 as well.
Fuse
Post by Fuse »
pettaw wrote:The ATF spec you're quoting is for different gearboxes, the M45R and M47R units fitted to 300s are different and all use ATF type A/A, the closest modern equivalent is Dexron, a friction modified oil.
I've got old Volvo books which quote Type F oils for all M45,M46 and M47.. Mobil 210, which is old type-f oil. (Though 740 manuals quote Type-F or Type-G)
shimon340
Post by shimon340 »
hi Andy /Pettaw and Fuse..
Ive checked a number of green volvo books, owners manuals and autodata. so far, everyone says ATF type F.
The only ATF tpye A/A listed is by haynes and the haynes 340 book is full of errors.
10w40 doesnt make sense... going to do more research on this before.
where did you hear of using ATF type A/A apart from Haynes?
both the 1980 green books and an 1989 owners manual version all say ATF type F.
I think Ive found a comma product which is type F. matches what you are saying Fuse in that it is listed as a ford oil...
Enjoy your 300s
Fuse
Post by Fuse »
Yeah my green books also say type-f so I trust those. Also every "volvo-guru" who I've talked to have used type-f. Owners manual and even my Alfamer (translated from Haynes) manual says type-f Mobil 210 so I think that the original Haynes one has an error, because all original Volvo books and manuals say type-f. ;)
One "volvo-guru" told me that friction modified ATF is too "slippery" for synchros in Volvo boxes, that's why type-f is recommened. Of course it works with friction modified too, but I would guess it isn't so good for synchros..
dalahare
Post by dalahare »
The type F tranmission fluid is used in one of the best selling cars here in aus, the ford falcon, you can buy 5 litres of the stuff here for about $25au
I got my data from the official Volvo green books (copy of which is in the technical section on this site) for the 300 series gearboxes, also the specification sheets. AFAIK they were the lastest version's that Volvo produced. The owners manual I have from 1988 doesn't give a specification, it just says ATF. ,
Its also stamped on the side of the gearboxes. A/A
EDIT: how odd, the owner manual from 1989 gives the spec as F or G.
