1983 y reg 1.4 brake system
kevywevywoo
no 14 please
[img][/list]
- foggyjames
Hi Kev,
Have you uploaded the picture to a hosting site? If not, try something like www.photobucket.com, which will then enable you to pop a link inbetween those IMG tags.
Good luck with finding the part - I'll keep my eyes peeled for you.
kevywevywoo
yup
its in volvo owners club couldnt see how here
- foggyjames
Ah...it's a PDF. You can only directly link a picture file such as a JPG.
I've hooked you up...as the man says, it's part 14...
Good luck with this. It might be tricky. We'll do what we can.
kevywevywoo
well good newa
met a guy near airdrie with loads of volvos only 9s+7s but he advised that the part im after will not be porous so more than likely a pipe or the seating for the pipes that are leaking so heres hoping
he knows them inside out and told me to leave his details if u ever get stuck for a 740 or 9 part ....jim 01324851225 mob 07742437850 said he,d be happy if anybody wanted advice too
- foggyjames
Well now you come to mention it, I was wondering if the failure had definitely been correctly diagnosed. How did they come to blame that part? What are the symptoms?
If the system is losing fluid, and it's not obviously going anywhere, try looking at the servo and rear wheel cylinders.
kevywevywoo
its
its at the bottom of the valva which is situ,d on inner wing but a closer look is reqd
