Speakers
retrocool73
Speakers
My 340 will be ready in the next week, I've bought some decent Kenwood 3-way speakers to replace the crappy original ones, same size... trying to remove the old speakers from the shaped plastic surround with great difficulty, can it be done???
B mk2 1.4GL 3-door57K xSTOLEN PRESUMED CRUSHEDx
E 360GLT Injection 4-Door Red 45K MINT
E 1.4GL 'Special Edition' 5-Door Met.Blue 72K
F 1.7GLE Ltd Edition 4-door Met.Grey 56K
F 360GLT Injection 5-Door Black 106K
G 1990 1.4 5-Door Dark Grey 108K RESTORED
- filthyjohn
IIRC, just gently pry the covers off with a flat screwdriver, then there should be 4 screws holding the speaker in. The plastic covers only just fit over the OEM speakers, so you might need to get busy with a file to get them back on, or just leave them off like I did
- petefarrell360
From what i remeber you have to flip the front cover off undo the 4 screws and that takes the speaker off comple with the plasic. You can then seperate the plastic from the speaker.
- petefarrell360
- foggyjames
I think our original posted wants to know how to remove the original speaker cone from the mounting frame. It's glued in pretty effectively, from what I remember. I think I gave up trying to get mine out.
retrocool73
Basically, using a flat-blade screwdriver, the old speakers have to carefully prized the plastic surrounds and the new ones fitted in their place.
In case anybody wants to know, the speakers I have fitted are Kenwood KFC-1061S
1988
