renault 5 gtt conversion
Posted: 06 Sep 2007 05:27 pm
by kms racing
iv just brought another volvo but its a 1.4 and iv got a r5 gtt engine lying around ,has this conversion been done and what would itvolve ,i think it would be quite strait forward because they are the same basic engine
any help much aprecated
nick
Posted: 06 Sep 2007 10:24 pm
by 340GLT
Basically the engine will bolt in, however turbo manfold wont clear brake servo so a new one requires fabbing up. Obviously with exhaust to suit.
Oh the standard 1.4 fuel lines are 6mm feed and 4mm return IIRC, so they may need changing.
The only other prob you may have is a clutch to take the power.
As in my 16v 340 i am using clutch components from 3 diff cars to make my own hybrid clutch, although similar, none could be used on the 1.4 lump.
Posted: 06 Sep 2007 11:11 pm
Adam has pretty much said it all. The exhaust manifold kills it for me. Although the GTT motor is a cool little engine, it's now in a much heavier car than a R5, and I suspect that many of the big-power ones out there exist because there's a wealth of knowledge and experience, rather than that there's anything too amazing about the engine.
Someone ought to do it (well....Frits is well along with it...but someone else too!) just because it's cool....but I'm not convinced it's the ideal engine for a 300.
Posted: 07 Sep 2007 06:43 pm
by kms racing
cheers guys , iv already thoughtabout the turbo and the mainfold ,iv got loads of stainless lying around so i was guna get techincal and fab up a new mainfold ,
will the r5 cluch fit as its got a fast road cluch kit
Posted: 07 Sep 2007 07:30 pm
I think you'll need to use a Volvo-specific disc. A good clutch place should be able to make you a suitable hybrid if you take them a 340 disc (for the centre) and a GTT disc (as a pattern for the friction material & diameter).
You could do a trial fit of the standard GTT clutch with a 1.4 clutch output shaft. I have a spare one you can have...it's bent on the prop side, but it'll do for a fitment test.
Posted: 08 Sep 2007 04:57 pm
by Frits
Hi Nick
Here you have the link to my topic.
You also need to change the sump, and a few more things.
Posted: 09 Sep 2007 10:24 pm
by kms racing
cheers for that link Frits that will help alot ,
iv just started to take the engine out tonite ,but it got to dark to continue , i will get some piccys tomoro
Posted: 10 Sep 2007 05:59 pm
by kaos
will follow this as its something i'd like to do...
