Hi,
Was changing the springs on my 360 and eviently the threadlocker that volvo or whoever used was strong enough to wreck the thread on one of the strut retaining bolt holes on removal!! Hence I now require a strut top mount.
Jason
Help! need a strut top mount!
Hello, they very expensive, if you can find them. If its just a threaded bolt hole, you might be able to find a friendly workshop blokey who could re-tap the thread for not very much, or possibly nothing at all. Cheers, bogbasic.
If the rubber is not cracked then you should get away with grinding the nut off and using a nut and bolt.
The the rubber is starting to crack new ones are only about £30 a peice
I've never had that problem before. The loctight normaly seals them up stopping them from corroding
