1.7 with single bike carb?
germ
Post by germ »
i had a thought about putting a single bike carb(40mm) on a moded 1.7 manifold,
would it be possible and would there be a power increase?
1.7i project fell though :cry:
will
Volvo 340 Image 1988
I doubt you will get any power increase with a single carb. If you had a manifold made to take two then I can see a possible flow improvment.
Whats gone wrong with the 1.7i Project? I may have soem of the bits you need.
griffo20022
Post by griffo20022 »
For what it's worth wouldnt you be better off getting a full bank of four and have a custom fannimold made up by somebody like Boggbros?
There cheap enough anyway. Unless your working on a specific budget??
'90 340 1.4 Vince!
'94 BMW 325i Saloon
germ
Post by germ »
cheap as poss :? my dad basically told me not to touch my engine unless it blows up...... coz i was going to fi it got the engine and found the head was warped and the bodie was worn out,
thinking 1.8spi from laguna again now.. just waiting for my engine to give it up :(
problem its solid as a rock hence the bike carb idea to solve the fueling problem.
specs of 1.8spi not bad... on fuel econ.
Max Power (bhp/rpm)
95/5750
Max Torque (lb ft/rpm)
104/2750
Town mpg
25.2
Out of Town mpg
35.3
Average mpg
44.8
Fuel
Will
Post by filthyjohn »
I had a 2.0 laguna and it went quite well for a big lump of france. Probably the same block as the 1.8 and there should be no price difference by now. Correct me if I'm wrong...
Its the same as the 440 bar the manifolds etc. The 2ltr is a good lump - its been great in vickys car.
Ronnie
Post by Ronnie »
germ wrote:just waiting for my engine to give it up :( problem its solid as a rock
Drain the oil out - rev it to f**k, and then when it blows up you can shout "Dad! I need a new engine..." 8)
http://www.filterfeeder.eu
germ
Post by germ »
^^ sm53
worth a try :P
germ
Post by germ »
btw interesting my car dynoed 110hp...but its a fake figure theres a big fiddle going on in france, found out iam making around 93hp's
:cry: (damn fr@#s)
Why not close up a couple of the plugs and put some oil in the petrol - that will make the engine seem buggered without actualy killing it!
germ
Post by germ »
so, the 2.0 lump from the laguna makes 5hp more than the volvo mhhh, and it will drop stright in with out intake issues ie throttle body right in the air box bit? there will be room to put a air filter?
my dads acording the swap aslong as i dont ask him for any help and pay for it myself :lol: :P
will
You need the early 440 injection inlet manifold or a carb.
The normaly 440 manifold could be used but the heater box would have to removed to make it work.
this is she manifold you want
Why not swap the EFI parts onto the existing engine? If you can't swap engines, I'd either go EFI, bigger downdraft carb, or venturi-per-pot carbs like DCOEs or the bike carbs.
germ
Post by germ »
wait a sec what efi/size engine is that :shock:
Edit* thanks for the piccies too, need to know the year for that too :lol:
will
