1.8 16v with bike carbs - help
Posted: 04 Nov 2007 11:41 am
by sps
hi
Ive fitted everything together on the car after getting a full ignition set up off a late 340 and got a spark at last. My problem is that everything is fitted and working but the engine will not spring into life.
The set up we bought for the carbs is very horizontal and i thought that it might be the issue - do the carbs need to be at an angle for the fuel to go in properly? Does anyone have any pics of an engine with bike carbs on so i can see what it looks like?
Thanks
S
Posted: 04 Nov 2007 12:02 pm
by griffo20022
Hey dude I didn't build mine so I can't help you out much. What fuel pump you using? Mines running using the R1 fuel pump aswell if thats any help to you?? Heres a pic.
Posted: 04 Nov 2007 12:23 pm
by swordfish210
Bike carbs are very good because they are able to run at a wide range of angles unlike webers. As mentioned earlier check the fuel pump is functioning properly
Posted: 05 Nov 2007 02:05 pm
Are you getting any fuel come into teh engine at all?
