as above i need to adjust my float in the carb as my car is bogging down on tyte corners, i have the pan filter out of my way and was wondering what next????
thanks for eny help
how to get to the float???
setsunakaede
Remove the bolts which keep the carb cover in place, and I thought you also need to remove the bolts which hold the carb. Then carefully lift the cover, the float will come along with it.
It is for the 1.7 is it?
I think you better change the float completely as it is "renowned" of changing into a sinker over time. It ain't that expensive, I reckon about 30pound at the renault dealer.
Vroom, vroom, vroom
Check out my website: www.vanabs.nl
You need to turn the top plate over (is the main gasket ok?) and measure the distance from the top of the float to the carb top plate, when (this needs checking... either the floats are touching the ball bearing in the needle valve, or are pushing it fully down) The measurement you require and the where the ball should be bit are in the 1.7 engine green book in the technical section.
To check the float, just get a bowl of water and see if it... floats
I held mine by the pivot whilst testing
EDIT: forgot to mention how to actually change it.... bend the cenral tab that rests against the ball bearing!
