Steering Dampener Woes
Ronnie
Post by Ronnie »
Hello folks
Today I decided to swap out my old steering dampener as it was looking pretty shabby. Was a b***h to get at, only enough room for one hand at a time. Got all the nuts off but then it became clear the dampener itself wasn't going anywhere. The part is a rubber disc about 10cm across with two perpendicular studs mounted in it. The steering shaft is in the way of the dampener, so there really isn't enough room to withdraw the studs out of the steering rack shaft. I manages to get it out with a friend pulling hard on the steering wheel to give me a bit more of a gap between the two shafts. But the new dampener is in much better nick than the old one (obviously), more rigid and basically impossible to get back in.
I did this job years ago on a Mk3, and I don't remember having this problem. I'm pretty sure that the dampener is closer to the rack on a Mk3 so there's more articulation of the steering shaft UJ available to get it clear.
Does anyone know what I'm talking about?
Anyway, it got dark so had to abandon. Tomorow I will jack it up and try to release the rack, It only needs to drop about about 1cm to give me enough room to get the new dampener in.
Any suggestions or previous experiences with this gratefully received
http://www.filterfeeder.eu
Can't help... but didn't think Mk3's had a rubber dampner...
Ronnie
Post by Ronnie »
Well there's metal in there too, but it looks like rubber - both my previous Mk3's had them. I'm sure all non-PAS 300's have them in fact.
The 300 Clarkson drove into a tree while complaining about vague steering obviously had a knackered one. It's a design fault.
jarlidge
Post by jarlidge »
hi
if its the dampener on the steering shaft i think you are on about you can knock the bolts out to slide the rubber out, all mk3 volvo's have these rubber dampeners. i know i replaced to on a car i got because it always splits after about 3years.
i hope thats some help to you.
jeff
Ahhh... non pas that'll be it?
Ronnie
Post by Ronnie »
Jeff, you're a life saver - V3M comes the rescue once more. I thought those studs were sealed in, but a couple of persuasive taps and out they pop!
It'll take me 15 minutes to sort this tomorrow rather than the 4 hours I was expecting to spend crawling about underneath my car in the cold!
jarlidge
Post by jarlidge »
glad to be of help,
hope it goes all ok.
jarlidge
Post by jarlidge »
the non pas had the rubber dampeners and the pas didn't
jeff
I bought a pair of dampers a few weeks ago, Kar's got no rack in atm, so that was easy to get out (and put back in hopefully ;)) Was tempted to do Fakes next weekend, but theres an engine and rack in the way :lol:
How long you reckon it'll take Aaron? Was impressed they still had the part tbh, I got one for each car as they had them.
How much are they? Chris keeps badgering me to do the 343's after I complained about its steering....
Ronnie
Post by Ronnie »
Chris_C wrote:How long you reckon it'll take Aaron? Was impressed they still had the part tbh, I got one for each car as they had them.
Probably about an hour, although it took me longer because I didn't know those studs came out! There's very little room in there, the master cylinder and the exhaust manifold strut are both in the way. I used a 13mm ratchet spanner, a short 13mm spanner and a hex key too. A friend to hold the steering wheel is useful!
SteveP wrote:How much are they?
About 15 quid delivered
jarlidge
Post by jarlidge »
i little tip is to undo the exhaust down pipe bracket and swing it up out of the way, that gives you a little more room to work around!
jeff
Ronnie
Post by Ronnie »
All sorted, fiddly bloody job. Didn't go for the exhaust bracket thing, mine is secured in 3 places by big rusty heat seized bolts which are even harder to get to than the dampener :D
Steering feels much more direct - thanks again, Jeff for your help!
jarlidge
Post by jarlidge »
no probs happy to help!
