Rogered B14 340 to pillage in Bristol
I've been scavaging an '89 B14 340 of late. It's lowish milage and has a blue interior. It's in Bristol and folks can have anything I haven't already snaffled from it gratis. It's going to be towed away some time in the new year, needs to be left rolling.
I'm taking the diff if I can get it off easily, but will be leaving the rest of the oily bits alone. Have taken quite a bit from the interior.
- trabitom99
Hi Aaron!
Any chance of you being able to pop the headlamp wiper arms into the post for me? John was a great help in salvaging motors & wiring, but someone else got to the wiper arms first ...
I'd also be interested in the wiper arm for the rear hatch, but that'd probably be too much hassle for you (bigger envelope).
Cheers,
Cheers,
Yes, but you'll have to come to Bristol and get it off yourself!kaos wrote:Any chance of the bell housing?
Yes and yes - this I can managejarlidge wrote:is there any chance does the 340 hace a blanking plate on the opposite side of the fag lighter. if so any chance i could have it.
Has headlamp wipers but also has front end damage, and am pretty sure at least one arm is knackered. I will have a look. Rear wiper is doable. I don't mind posting things on at your expense.Tom wrote:Any chance of you being able to pop the headlamp wiper arms into the post for me? John was a great help in salvaging motors & wiring, but someone else got to the wiper arms first ...
- trabitom99
OK, that's great thanks! Don't worry to much about the blades themselves (unless they're still good) it's more the arms I could do with (and the nuts & bolts holding them to the motor).Ronnie wrote:Has headlamp wipers but also has front end damage, and am pretty sure at least one arm is knackered. I will have a look. Rear wiper is doable. I don't mind posting things on at your expense.
Hello, I need a brake servo. If its still available, would you be happy to remove and post it?? Cheers, bogbasic.
michaelodonnell500
Hi would i be able to take the windscreen?
I just cracked mine today unfortunately!
if It is up for grabs it would be ideal if i could pick up on the 27th. I live in Slough but i'm visiting friends in Newbury for Christams so it would cut down on the mileage if i could get it on route. Failing that any time that suits you would be fine.
Thanks
Michael
Thanks
Michael
- filthyjohn
Oh crap! I forgot to put your wiper arm in the parcel !!!trabitom99 wrote: I'd also be interested in the wiper arm for the rear hatch
I'll send it on as soon as the post office opens again.
- trabitom99
No worries John, I only need one! If Ronnie's up for posting it along with the headlamp wipers that's fine ...
I was outbid on a set of brand new headlamp wiper blades last night, but AFAIK they're still available new & fit other cars as well (Sierras?).
