300 Parts Clearout !
***AMENDED PARTS LIST***
new unipart 360 clutch £25
new water pump for 240/740 early 360 £20
coolant tank & cap £5
GLT ECU £10
renix unit code 412A £10
airflowmeter 360 £15
virtually new 1.7 alternator (lucas) £20
black vinyl rear headrests £10
wheelbrace £5
instrument cluster with clocks £10
boxed new front door speakers £10
radio reducer plates for din size radios £5 each
GLT air idle valve £5
1.4 bellhousing sensor £5
m3 small silver hubcap £5
Cheers,
John.
Leave a pm, reply or email me at johnallam@btinternet.com or ring me on 0771 2802774. Located in North Yorks should you wish to pick up.
Cheers,
John.
GLT ECU £10
wheelbrace £5
Cheers,
John.
Cheers,
John.
Steve, it's the bit that goes next to the glass on the front & rear door pillars - I can't think how else to describe it really ? I know it was only on the 360's & the redlines.
I'll get back to you both with postage costs, unless Mr F.James is coming up to get the 300 register keeper stuff off me shortly !!!
Cheers,
John.
Cheers,
John.
Current : No 300's anymore !
- foggyjames
That'll teach me to not check V3M...just posted on the VOC saying I'd have the lot! I'm sure we can work something out guys
- trabitom99
Will PM as well! Am in dire need of a B200 360 water pump (3344252), and would also be interested in:
boxed Volvo cambelt B200 £5
volvo oil filter £5
GLT renix unit £15 (what's the type number on it?)
3rd rear brake light £5
black vinyl door sticker for 360 models - top part between glass £5
and if SteveP decides not to have the sunroof panel after all (wishful thinking
good sunroof panel I.e. no rust £20
Cheers,
volvo oil filter £5
Cheers,
- griffo20022
Does the oil pressure gauge come with all the gubbins to fit it? Is it an electrical sender or mechanical? I'd be interested if it were electric
EDIT** Just had a look at the leaflets and I assume it's electrical? If so i'll take that mate! Should fit in a 1.8 16V clio engine still shouldnt it? Would have thought the thread would be the same?
'90 340 1.4 Vince!
'94 BMW 325i Saloon
'94 BMW 325i Saloon
If Steve and Tom don't have the black stickers for the B pillars, I'll take them!
If there's anyway of getting the red wing down South, then I'd be definitely be interested in it!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
- foggyjames
Just a thought John...it seems that B19 360s used a standard 2/7/900 series water pump...so you may not have been lied to, as such
Have just put a few items on fleabay including 4 boxed black vinyl transfers that go on GLT /Redline doors I've found !
Also on are the boxed speakers, clutch kit & a 1.7 alternator.
Foggy still has an excellent grey hatch parcel shelf of mine should anyone require one !
Cheers,
john.
Cheers,
john.
- trabitom99
Hi John!
Weren't the bits of vinyl trim part of the parts lot for me which foggy's storing at the moment?
Or maybe you had two sets ...
