360 GLT on Retro Rides
- filthyjohn
this is mine.
i was just on way over to put it up here, but thanks.
here's the full ad:
condition is probably a bit below average now, but it has tax till end of March, and test untill sometime in March also.
Mileage is 134k, but it still runs nice. Not quick by any means, but drives nice, and has never let me down.
Body is a bit tatty, few small rust scabs here and there and the whole thing could do with a T-cut if you were that way inclined. The sunroof is a bit shagged, and is taped up to cut out the wind noise. same as the drivers window, as the motor is on the blink.
tail light is cracked.
the gear linkage is very sloppy, and wont get gears fully if the gaitor surround is in place. It's fine with the gaitor off, but then it lets the sound of a rattle into the cabin.
It has a radio/cassette, but the front plate has come off. still works fine
It's a good car and would do someone a good turn if they put in a few hours with it for the next mot.
I've not really done anything with it apart from lower it with spacers at the rear and chopped one coil out of the front. the diff was welded, but that has since broken and the diff is back to normal. I need the can that's on it at the moment, so it will come with no back box.
Please direct any questions to handleymyke@aol.com or 07773845713
It's in High Wycombe.
New car coming next weekend, so £200 takes it.
here's the full ad:
