Breaking Volvo 360
volvo360gls
Breaking Volvo 360
It is with much regret and sadness that I type this thread. Due to a change in financial and personnel circumstances I can no longer afford to keep going with my 360 project. So the time has come to sell.
I purchased her last June as a standard 1985 B reg 360 with 114k on the clock with a view to creating an enjoyable rwd trackday car. She was structually sound with rust limited to both front wings, the front valence panel and the edges of the inner win.
Following a thorough strip down and rebuild the engine was swappred for a 2.3 b230k (with ported and polised head) and twin weber 40 carbs installed. The suspension was overhauled and renewed or replaced where wanting.
And that brings me up to date. The work outstanding on her is limited to bodywork and tuning. She needs rolling roading to have the carbs correctly jetted and setup (approx 150-300 depending on skill / time taken / parts needed). in order to achieve a conservative 140bhp.
However due to the sad world we live in the truth is that shes worth considerably more being broken for parts then sold on whole. The following is a list of performance parts fitted, also there are most normal bits off a 360 left that still have plenty of life in them so may be a good time to stock up your spares pile. Right, here goes:
-2.3 b230 k with ported and polished head
-twin 40 dcoe webers
-twin carb manifold
-genuine weber throttle linkage (can use orig. volov throttle cable)
-fuel pressure reg, with gauge and built in filter plus spare bowl, filter and plug screw
-new battery (only filled with acid 3 weeks ago)
-new master cylinder
-2x new front brake calipers
-new blackdiamond groved discs
-black diamond predator pads
-brake drums and shoes plus fitting kit
-goodrige braided brake hoses
-all new copper nickel hard brake pipes (much more resistant to corrosion)
-spax rear adjustable shocks
-off of Dai, custom front mono tube dampers
-front 3" lowering springs
-rear 2" lowering blocks
-new polybush anti roll bar fitting and link kit
-all polybushs for front suspension
-front struts have had new spring retaining cups installed (why worry about rust!)
-2xOMP bucket seats installed (using custom framework) onto volvo runners
-oil pressure and watertemp gauge with all wiring
-5XFox 5 double spoke 15"alloy wheels. 2 with nearly new khumo tyres and 2 with part worn toyo T1s tyres. Fifth wheel has no tyre.
All this is in addition to the standar 360 stuff. Its all got to go so rather then me price things just drop me a pm and we can haggle.
Regards Rich
ps sorry for the long post just im quite sad that this is the end for her.
-twin carb manifold
Regards Rich
PM sent about the above...
Re: Breaking Volvo 360
Have pm'd about the below bits...
-little GLS cap things that go inbetween the wheel nuts!
EDITED: So it only says what I'm actually taking and Rich can hopefully sell the other bits easier.
volvo360gls
volvo360gls
volvo360gls
- griffo20022
- filthyjohn
I did the struts for Rcih so they are done properly.
volvo360gls
Also knocking around needing to go
set of piston rings for b230 engine
2 x fan belts
QH standard shocks for front
The original springs (maybe ideal if some one wants a cheap cut down set)
Original manifold and carb off volvo 360, was in full working order when removed.
Plus all of the boring stuff needs to go like
Alternator,
Starter,
Dizzy cap and rotor arm (less then 4 months old with little use)
Im looking for £50 for the b230k engine, which will consist of bottom end, and ported and polished head. Delivery may be possible locally for the right money as i have my own engine crane, hell may even help fit it! Or lend you my crane.
Rich
2 x fan belts
Alternator,
Starter,
Rich
volvo360gls
volvo360gls
Bumpty Bump!
Still plenty of parts left to go,
All glass on the car is available (apart from rear pop out windows)
£20 for both front windows and £20 for the windscreen - make great spares
THe boot is in good condition to so is the bonnet. Ideal to have on stock £15 for each (boot will include glass).
4XStock volvo wheels, The steel alloy look a likes. Need work but are a cheap set at £20 for all 5. Tyres all have several mm left on them.
Starter and alternator are perfect aswell.
Not worth having to hunt for one when yours breaks... when im charging £10 each.
QH front shocks, never used Brand new in box, bought but then went with Dai's mono tubes. ideal replacement for a cruiser or day to day car. £50 for the pair.
Plus front brakes are still to go.
£30 each caliper, brand new - no need to send yours away for a good price, kep em as spare.
£80 for as good as new black diamond grooved brake discs, look cool; being black,
£20 for a new set of black diamond predator pads, only been oin car few months during which has done less then 2 miles.
All brake hard pipes are for sale as well along with brake splitter and regulator. Ideal back up units. All hard brake pipes £20. Brake splitter £5, brake t-piece £1.00. Servo is still in full working condition £20-very hold to find new ones or repair kits, and even then they're n ot cheap.
Any way there's some more food for thought.
Rich
Rich
- filthyjohn
There's a meet coming up soon near Milton Keynes:
http://www.volvo300mania.com/forum-uk/v ... sc&start=0
Kidderminster isn't far away, so you could come along and join the fun, and bring bits if you have a van
Or since we'll be in the area(ish), we could all come round and descend upon your car like locusts...
Just a thought.
Cheers,
John.
Just a thought.
Cheers,
John.
