help with rattle
Posted: 24 Nov 2004 12:44 am
by special
i have an anoying rattle when reving up
it sounds like valve clearence rattle however i have checked this and there all ok
the sound is comin from the bell housing area its not the clutch
the only thing i can see near it is the exhaust heat shield for the down pipe
but i cant imagine its that
any thoughts would be apreceated
(the rattles been there about 6 months but has not got any worse)
stuart :?
Posted: 25 Nov 2004 09:47 pm
by Kyuss
not sure if this is way off the track, but i owned a Holden Rodeo - i think this is an Isuzu Passport for you guys... and had a noise as you describe. In it's case it was the airconditioning compressor clutch which had failed.
do you have A/C and has it failed?
Posted: 26 Nov 2004 05:45 pm
by special
er no but thanks for the sugestion anyway
Posted: 29 Nov 2004 12:47 am
by 5lab
one of your exhaust mountings is snapped. should be black rubber. might be further back than your expecing (level with the b pillar maybe). replace. cost £5
Posted: 29 Nov 2004 11:40 am
by SoLaMaNdA
If its quite loud then it could be as 5lab said, an exhaust mounting rubber which I've picked up for £2. What engine is it? My 360 has rattled at exactly 2000rpm for years. I've never been able to track it down and it still runs fine.
Posted: 29 Nov 2004 11:22 pm
by special
i shall have a look at the week end thanks for the advice sm40
(whats a b pillar?) :?
Posted: 29 Nov 2004 11:25 pm
by redline
the one between the front and rear doors
