Sump 1.7
TESA
Sump 1.7
Post by TESA »
Hi there do any one knows if 1.7 renault sump is the same as 1.7(B172) volvo sump ?
thx
Post by 340GLT »
No its different.
TESA
Post by TESA »
Oh sh.... Ok. So I am going to modify F7P sump to fit in engine bay... Cause in CZE there is a big problem to get spare parts for this cars...
343 dl
Post by 340GLT »
The engine mount for the 1.7 bolts to the sump.
TESA
Post by TESA »
Ok, I have modified sump...
And what about clutch plate ? From which engine do you use it ?
343 dl
WooDooUK
Post by WooDooUK »
I have fitted a 1.7 clutch plate with the renault clutch cover in mine and that does the trick, However i did have to modify the engine mount bracket (read attack with grinder) as it seems to move the clutch fork, which now fowls the mentioned engine bracket.
