Sun roof mechanism
CarlD
Sun roof mechanism
Post by CarlD »
I know there's not much chance finding a working sun roof mechanism (metal slide and tilt) for a 340, bit i thought i would put a feeler out just in case as i seem to be slowly working through tiding up the car. So if anyone has or know where one might be available it would be much appreciated.
Carl
Post by trabitom99 »
If you need a panel, I may have a spare one originally from JOHN360. It's at Foggy's at the moment ...
Carl, if you cme across a second set of cables, I know a man who'd bite your arm off for them ;)
Tom, is this panel still available, I thought you offered me first dibs on that particular one?
CarlD
Post by CarlD »
The panel i have is fine.
What i'm after is just the full mechanism as i think Chris and a few other people have mentioned at meets that if it's broke it all needs replacing, excluding the panel.
I've got a sneaky plan for fixing snapped brackets, no idea if it would work though. By brackets I mean the white plastic bits on the cable, if the cable's stretched I think it's game over.
I reckon the brackets could be replaced though, using Polymorph or similar. Other idea is to look at VW ones, has anyone confirmed how much of that roof is the same?
SteveP wrote:Tom, is this panel still available, I thought you offered me first dibs on that particular one?
Steve, I did, but I understood at the time you didn't want it? I've never seen it, but from what John said it's good but not absolutely perfect.
JOHN360 wrote:there are a couple very small bubbles in one corner
JOHN360 wrote:the bottom side it very sound from memory, just those couple on the top bit ! The seal is also fine !
Perhaps Foggy knows more?
I asked foggy about it recently but he understandably said it was still yours at the time, would certainly be interested if its better than mine.
In that case, consider it yours :-)
Chris_C wrote:Other idea is to look at VW ones, has anyone confirmed how much of that roof is the same?
So far, only the winder handle and the seal. It wouldn't surprise me at all though, if other Golde bits fit too ...
CarlD
Post by CarlD »
Now i didn't know that there may be some similarity between VW sun roofs, any idea what flavor of car? I'll have a ring around the people i know with vw's and see if they will allow me to have a poke and a prod.
Hang on i have the etka on disk, i wonder where i put that sm14
Thanks Tom, I probably didn't make it very clear as at the time my 360 was annoying me :lol:
I've been trying to figure out if similar aged VW's used common parts with 300 panels, also take a look at Audi's too... unfortunately not found another with the same panel :(
CarlD wrote:Now i didn't know that there may be some similarity between VW sun roofs, any idea what flavor of car? I'll have a ring around the people i know with vw's and see if they will allow me to have a poke and a prod.
Quite a few cars had Golde sunroofs, air-cooled VWs, Golf Mk1 & Mk2, Scirocco, BMW 2002, and AFAIK some of the bigger Volvos too ...
Only the seal from a 1303 Beetle and a Mk1 Golf is confirmed as fitting though. If you could shed some more light on as to which other parts are interchangeable, I'm sure that info'd be most welcome here :-)
kesk
Post by kesk »
I have one sunroof from a Volvo 340 that I purchased from a scrapyard, but this one does not look like genuine Volvo accessories. It can't slide, just tilt.
Here are some pics:
I don't need it, I would give it away for the cost of shipment. But I live in Bosnia and that could be much!
