Hi well im thinking of starting a volvo project involving the swap of a CA18DET engine and running gear into either a 360 or 340.
My question is how where your insurance companies when you informed them of the engine swap and what companies do you use. Id like to get an idea of the cost before I make a go ahead.
Thanks.
Engine swap and insurance.
Not sure as to why you'd want to use a CA18DET... a turbo redblock engine can be had cheaply and is just as tunable and doesn't have fragile big ends like the Nissan lump. The 300 series uses a transaxle at the rear of the car so mating up the gearbox and drivetrain from the Nissan may prove tricky.
- foggyjames
It depends hugely on exactly who you are, what you're doing, and who your insurance company is. It will typically range from zero increase to double the 'standard' price.
The more 'factory' what you're doing is, the better, generally.
Indeed, if you can just say you've got a 360 but its turbocharged then its a lot easier than saying you've done an engine swap. If your going to all that bother of fabricating a new transmission tunnel, etc why oh why put a CA in there, coming from an SR owner, let the debate begin haha, but seriously, if your doing so much fab work you could drop in something with more cylinders or something
1988
