steering play?
Posted: 05 May 2008 03:25 pm
by jamie_stafford
i use my 360 glt for drifting and i am finding it real hard work keeping it sidways as i am haveing to corect the steering so much, how much play should there be if any?
Posted: 05 May 2008 04:17 pm
by jarlidge
not that much play. is you 360 got power steering?
Posted: 05 May 2008 04:29 pm
by Tourinki
Check the suspension and steering and replace those parts which have play in them. Or you could buy some parts which aid to keep the tail on the side.
But 360 doesn't really like going sideways. Almost everytime when i span it it was cause of turning it against steering lock. And also lack of power... I wasn't able to get it going sideways when going over 70 km/h.
Posted: 05 May 2008 04:36 pm
by jarlidge
if the car hasen't got power steering you could check the rubber steering
damper, between the steering rack thats some times splits and makes
the car have a lot of play on the steering.
Posted: 06 May 2008 09:31 am
by jamie_stafford
thanks, mine has no power steering so i will have a good look at it tomorow, my car seems to love drifting in 1st and 2nd gear and only in 3rd in the wet but i have welded my diff.
Posted: 06 May 2008 12:59 pm
I agree with Jeff, the damper is very close to the rack, protected by a plastic cylinder (coke can sized). Cost's abotu £12 from Volvo for a new one, but a bit of a pain to get too.
Posted: 06 May 2008 02:14 pm
by Ronnie
I agree with this diagnosis too. But just to note that not all of them had the 'coke can' cover, or have lost them over the years. It might appear as a dirty great big rubbery looking bush on the steering shaft just under your master cylinder.
Posted: 11 May 2008 02:43 pm
Also check the rack for wear
Posted: 12 May 2008 11:16 am
by jamie_stafford
it was the rubber bush on the steering shaft, had a grate big split in it, got one from the scrappy for £5
Posted: 12 May 2008 12:20 pm
by jarlidge
happy to help
Posted: 14 May 2008 10:47 am
by jamie_stafford
thanks for the help
