Electrical gremlins
Geez
Electrical gremlins
Post by Geez »
HI guys , need some advice ! My '88 GLT has developed some electrical problems . When I am driving does nt matter whether she is cold or hot the dashboard lights and head lights go very dim, if I switch the lights on and off a couple of times they come back on normally, Then this morning on way home after a nightshift the same thing happened but when I switched them on I lost all power she just died completely!!! TUrned the key got nothing no lights, engine, heater nothing! Then I took out key ,put it back tried to start her and she fired up perfectly everything working as normal. Does this sound familiar to anyone or any ideas or is she just haunted!!!!!!!!!! HEEELLP!!!!!!! sm44 sm51
360GLT E620OEW 1988
Can't do pics sorry!!
5lab
Post by 5lab »
sounds like a dodgy connection somewhere. i couldnt tell you where thou - possably the headlights?
Post by redline »
were there any bright lights in the sky when your engine died if so its the same aliens that took Dougle and the dumped car down my road, sounds like you had a lucky escape you could have been transported to the planet VOLcan sm66 sm66 sm66 sm66 . P.S. as Hugh said its probably a loose connection , try battery terminals , ignition switch , light switch and plug connectors at rear of lights + might be worth cleaning up earth connections,
DeKayDAD
Post by DeKayDAD »
Definitely loose or corroded connections check all main connections not forgetting the earth to body and earth straps. :idea:
Neil.(i'm not old,Im only 48)
Geez
Post by Geez »
Nice one cheers guys!! Will have a good look at weekend . There wre some bright lights in the sky but I think the source was in the Milton Keynes area :!: :wink: Think the car is haunted by a little ol lady who is scared of rivers (General forum, DONT GO NEAR THE WATER!)
360GLT E620OEW 1988
wjp01908
Post by wjp01908 »
Have a look at the thread on Ignition relay problems over in general technical.
One of the manifestations mine had was that the engine would die if you turned the lights on sometimes....
Will
tail happy torch boy twat
Post by tail happy torch boy twat »
Yup, sounds similar to my problem (the same as Wills') although not connected to the headlight switch in my case...
Current:
Volvo 360 GLT x2 (1989 / 1986)
Volvo 480 2.0i Celebration (1996)
Volvo 480 1.7i (1988)
Volvo 850-R (1996)
Austin Princess 2200 x3
Allegro Estate 1500 'Special' (?)
Mini 1275GT.
Past:
Volvo 360 GLT x2
Mini rust bucket
***BL Forever***
There was a thread about a week ago about one of the multi-pin plugs on the fuseboard causing general electrical faults - probably worth checking!
Post by Tom »
Mine seems to do this also, although not quite as serious as yours. When the engine is idling with no choke you can definately hear it growing weaker when you switch on the lamps. The courtesy light and most of the dash lights dim also.
F983 OHD '88 340DL - Gone but not forgotten
C299 LGF '86 340DL - Variomatic jerkiness
5lab
Post by 5lab »
you've not got a revgauge have you?
it sounds like you need to up your revs a tad - sounds like its idling a little slowly and the altinator isnt generating enough power to get the lights going. little more 'umph' would sort that, so sort your bloody carb out :)
Post by Tom »
5lab wrote:you've not got a revgauge have you?
It does idle a little slow. That's probably the problem.
5lab
Post by 5lab »
step 1 : get a revgauge
step 2 : install
step 3 : sort your carb
Hugh...you forgot stage 4...
4) Get and fit alloys.
Geez
Post by Geez »
Just a quick update, the poor ol girl gave up completely earlier in the week :( Have narrowed the problem down too either afaulty ignition switch or a break / bad connection in the wiring up to it . have got all electricds that run on a direct battery feed but nothing that runs through the ignition. Cheers for all your ideas and suggestions ,Will soon have her back on the road . . . . . . . . . hopefully :!:
360GLT E620OEW 1988
Geez
Post by Geez »
She s running again :!: :!: :!: sm69 Thanks to my brother. The problem was a multi plug connector that sits under the dash through the bulkhead connected to the back of the ignition ,had partially burnt out sounds like similar problem that a few of us have had now.
360GLT E620OEW 1988
