redblock turbo valves
shimon340
Post by shimon340 »
Hello
This isnt a pure 300 series question but there is some connection as people do 360 turbo conversions.
Does anyone with greenbooks know if the turbo redblock valves are sodium filled for better cooling? Do NA redblocks not have piston cooling oil jets?
Shimon
Enjoy your 300s
Ronnie
Post by Ronnie »
I believe the B230FT had sodium valves. Some blocks have oil squirters, some haven't. There's a load of stuff on Turbobricks about this kind of thing. A search there will give you plenty of info.
http://www.filterfeeder.eu
Post by filthyjohn »
Post '93 for oil squirters, turbo only iirc.
Jason B
Post by Jason B »
yep, turbos have sodium exhaust valves (though I'm not certain if that is for all heads) - and the oil squirters should be on any post '93 block regardless of induction iirc
shimon340
Post by shimon340 »
thanks guys!!
Enjoy your 300s
Bump!
All blocks (whether NA or turbo) had the squirters after a certain date. By that time they may have all been turbo anyway...I honestly can't remember. You can add them to any engine...but some in the year or so before they were fitted have the 'bumps' for the tapping, which makes life easier.
All turbo heads have always had sodium filled and coated exhaust valves. Having said that...it's not a problem to run without them. You may not get quite the same lifespan out of plain valves, but it's not worth swapping heads over. Many production turbo cars have plain valves.
