Difference between a B14 and a B172?
Justin
Post by Justin »
What is the difference between a B14 and a B172? Im assuming the former is a 1.4 and the latter a 1.7?
j
Post by trabitom99 »
Yup. Both are Renault engines, whereas a B19/B200 is a Volvo engine.
Justin
Post by Justin »
Thanks Tom, is the B19/B200 the number for a 2 litre engine?
Jus
Yes. The R-Sport 2 litre is sometimes called a "B21E", but the rest of the 2 litre variants are either B19A / B200K (carb) or B19E / B200E(EA,F) (injection).
kaos
Post by kaos »
also the mounting point son a 1.4 are different to a 1.7.
Bazboy
Post by Bazboy »
So how hard would it be to place a b19/b200 engine from a glt into a 1.4???
Bazboy wrote:So how hard would it be to place a b19/b200 engine from a glt into a 1.4???
You would need to replace whole driveline, also for MOT you probably need to replace rear brakes as 360 has bigger drums, but don't know precise law in UK. Engine mounts need to be replaced too, with B200K you also need fuel return line, but I think all 300 series cars had one, even 1.4.
It is quite lot of work, imo. Specially if your car is not perfectly rust free, I would recommend to find 360. But if you plan for using it to motorsport it should not be too much of work as one needs to take it apart anyway.
Jason B
Post by Jason B »
much easier to put a valver in tbh, and would probably be the best solution for modest power aspirations.
Bazboy
Post by Bazboy »
Whats a Valver??
Dan
pistonpen paultje
Post by pistonpen paultje »
1.8 16v or 2.0 16v Clio lump. Gives approx 140BHP
You'll need a 1.7 lump as a base for it, because you need parts of that one...
Post by 340GLT »
Kaos if you are talking about engine mounts they are identical.
kaos
Post by kaos »
adam mount points on the car are the same but not on the engine :)
Post by 340GLT »
Well yeh i thought that would be obvious its a diff engine.
Jason B
Post by Jason B »
lol :lol:
Justin
Re: Difference between a B14 and a B172?
Post by Justin »
It makes sense that a B14 is a 1.4 which is what the metal plate above my oil filter says but why does the B172 have the 2 after the B17?
1988 340 1.4 DL
