Putting a k-cam in B19E
Posted: 02 Sep 2008 07:46 am
by hodgy21
I recently aquired a K-cam from SteveP (thanks), and am about to install it in my 360, I was wondering if I would need stronger valve springs or any other uprated parts. Also, is there anything else people would suggest changing whilst I am under there.
Can I take any parts I might need from other volvo's?
Any help is appreciated.
Posted: 02 Sep 2008 04:52 pm
by Tourinki
Standard parts will be fine. But while you are changing the cam replace cambelt and tensioner. Because with K-Cam you'll end up with bent valves if belt snaps.
Posted: 02 Sep 2008 05:22 pm
by hodgy21
Awesome, Thanks for the advice I will make sure I replace those two aswell.
Posted: 02 Sep 2008 10:59 pm
I'd be interested to see how this works out. Conventional wisdom says that the standard engine management can't cope with changing hardware...so I'll be interested to see if yours behaves itself.
Oh...and the K really isn't that hot. It's a 270 degree duration cam, which isn't that wild. I get (got...I need to re-tune the carbs) 95% of peak torque from 2250rpm. As the others have said, standard valvetrain will be fine.
If the fuel system can deliver the goods, you'll love the cam!
Posted: 03 Sep 2008 08:02 am
by hodgy21
I also have quite a few other bits to go on aswell!
All will be revealed eventually when I get around to putting it all on, I have a completely different system lined up for the fueling side of things, but its going to take a while to build up some funds
Posted: 04 Sep 2008 01:28 am
Sounds like you have it in hand...cool
Tell me about the shortage of money situation
The 343 build still requires suspension goodies, exhaust, bodywork & paint.
Posted: 04 Sep 2008 12:38 pm
by Jason B
oh, just a thought... where do people get their redblock cam shims, from volvo? I haven't really enquired yet tbh and am just being lazy
- and yeah, funds are annoying but at the moment it's time thats holding me back
- I have a nice big pile of stuff to sort and fit soon just havent got round to it....
Posted: 04 Sep 2008 01:28 pm
by hodgy21
I have wheels, dampers, springs, blocks, cam, inlet manifold, roller barrel throttle bodies, injectors, management system, fuel pump, a very pretty rocker cover and a bunch of gaskets to go on, I just need some top mounts, time and a few more pennies and I can start putting it all on.
It is so frustrating seeing it all sat in the garage!
Re: Putting a k-cam in B19E
Posted: 04 Sep 2008 03:45 pm
by sven360
hodgy21 wrote:I recently aquired a K-cam from SteveP (thanks), and am about to install it in my 360, I was wondering if I would need stronger valve springs or any other uprated parts. Also, is there anything else people would suggest changing whilst I am under there.
It'll love ya for a decent porting job-time well spent IMHO.
Posted: 05 Sep 2008 07:23 am
by hodgy21
Cool might give that a shot too!
Posted: 05 Sep 2008 08:04 am
by hodgy21
Are these the correct volvo parts codes for the belt and tensioner or are they aftermarket ones?
Belt:- 271713
Tensioner:- 463633
I would prefer the OEM ones if anyone knows them.
Cheers.
Posted: 05 Sep 2008 08:13 am
by trabitom99
Those are the correct Volvo OE numbers as far as I can tell ...
Posted: 05 Sep 2008 06:34 pm
Yes, those are the correct numbers. I have a brand new genuine Volvo belt, if you want it for cheap.
Posted: 19 Sep 2008 03:14 am
by carnut1100
Absolutely change the belt for sure!
In the 245 I went from D cam to K cam and it picked up quite a bit of grunt but moved it up the revs a bit.
It starts to jump at 2500 and pulls until about 4500-5000 then starts to taper off.
I got to drive a 242GT with teh H cam and it pulls much higher but has less down low.
Fun to drive, but I seemed to be having too much fun in 3rd gear to spend much time in 4th....
