Changeing wheel bearing on my 340?
kris84
Post by kris84 »
Hi all i haven't had my volvo 340 very long but have blown my rear wheel bearing already :( i had a look into doing it to day but not sounding stupid i couldn't see how to changed it :? i no my way round a tool box but have never worked or owned one of these before. can anyone help please. :D
Post by filthyjohn »
You have to take it off from the back. There's a big nut holding the hub on from behind. I can't be more specific as my haynes is 6 miles away, and the relevant Volvo technical manual hasn't been uploaded to the site yet.
Pretty big job mind, probably easier to just fit a whole new axle (especially if you've had a 'disagreement' with a kerb and could have bent yours. I damaged my OSR bearing when I went through a pothole totally sideways (bloody council).
kris84
Post by kris84 »
Thanks for the reply, you say a big nut do you no where abouts its located?when i was looking there was alot of allen key nuts plus 2 maybe 4 12mm bolts on the back of the hub :? :)
rear wheel bearing
Post by MCHUDD »
I Had the same problem with my 360. Jack up car,take wheel off. You then need to unbolt the half shaft at the hub end.Only 6 bolts. when the half shaft is clear you will have access to the nut. You will need a hub puller also.Good luck with the job. Mine was a real b*****d to get off.
Aye sorry, forgot to mention you need to remove the shaft. 6mm hex bolts x6, then the big bugger is something like eleventy billion mm, but you might not be able to see it for thick grey grease.
kris84
Post by kris84 »
Cool thanks guys im going to attemp the job the weekend. Looking forward to this one :( evverybody i have spoken to says its a right pain in the bum. :(
It'll totally depend on how rusty your bolts are, there's a small chance you might not even get the driveshaft apart if the hex bolts on there are goosed. It'll not be too bad if they're in good nick though. Good luck.
