Hi everyone, I was just wondering. Im going to look at a car at the weekend but it has hardly been driven recently. well 3000 miles since 89' does this mean its likely the valve stem seals are likely to be perished and burning oil?
Matt
Valve stem seals
cheshire190e
Valve stem seals
1987 Volvo 340 1.7
Hi Matt,
3000 mls in nigh on 20 years - I should think quite a lot has perished !
Seriously - stem seals may well have perished but they're not the first things I'd worry about.
1. 20 year old tyres - bad news - they will have degraded and flat spotted (kept in the dark with car on blocks might have helped - but DON'T TRUST 20 yr.old tyres).
2.All rubber items in the braking system - seals and hoses. Master cylinder WILL have absorbed water and has probably rusted (brake fluid is hydroscopic (well hygroscopic actually and adsorbs rather than absorbs - but you get the idea)).
3.If car has not been moved regularly then wheel bearings (front and rear) may have "spotted" tracks.
4.Depending on where car has been stored you may have problems with door seals, window seals, and door hinges.
5.Exhaust is probably on the point of rotting out due to water not having been "boiled off"
6.Engine internals MAY have surface corrosion (above oil level).
7.If car is a 360/B172 then cam belt will have deteriorated.
8.General corrosion of electrical connections - rear lamp cluster bulb holders will be favourite.
A lot depends on where and how the car has been stored - and don't be too put off by the above (which are just my first thoughts) - BUT go into things with your eyes open and understand that any car not used for 20 (however well it has been stored) will require a gooooooood deal of recommisioning before it can be driven.
Mac.
Mac.
Mac, I believe this is the car in question:
http://www.volvo300mania.com/forum-uk/v ... php?t=7028
EDIT: point 2 in your list was a major problem for me, after my '75 Merc had been standing for only 9 months ...
cheshire190e
Yes, that is the car in question. by the looks of the pictures it looks in real good shape. door seals look pretty good etc.
from the old mot's it has been driven a steady 500 miles a year. its just passed an mot without an advisory.
ill keep my eyes peeled for perished parts
cheers guys
cheers guys
1987 Volvo 340 1.7
