360 fuel not gettting past mech. pump
Posted: 29 Nov 2008 08:07 pm
Hopefully one of you pro's will be able to solve the problems I am having with my newly acquired 360 GLS 2.0 carb.
I am certain that the mechanical fuel pump has given up the ghost. It sucks fuel up to about 3" from the pump and then it won't go any further.
I have used the search and there was one post by dr1fter that sounded like the same issues but it had not been resolved.
It broke down on me this morning, after taking an age to start and needing a jump, when it did fire up it wasn't happy idling and stalled a few times before I persuaded it to stay alive. It also chugged a bit on the motorway yesterday, fuel starvation? Today two miles down the road it began chugging, I pulled over and it died. Fired it back up and it wasn't idling - just cut out straight away. A mate took me for a fivers of petrol - I assumed this was the cause, because the light was flashing, even though there's loads of fuel in it...
It still wouldn't idle after the fuel was put in, then the battery was dying so we removed the pump to take apart and inspect to see if we could find the problem.
It was pretty gunked up inside, the gauze was choked up too, we cleaned it up with carb cleaner and petrol and put it back together.
Refitted to the car with new DIY gaskets, then the car would not even attempt to fire :S (maybe as it now had zero fuel in the pump?) It got close a couple of times but still was only drawing the fuel to about 3" from the pump then stopping. My mate sucked it through then quickly put the feed pipe back on and I tried starting it but the fuel just ran straight back down the pipe.
Called out the AA and he used a suction pump thing and it pulled it through no bother, so seems the pump is definitely at fault?
We were also wondering whether the gaskets were possibly spacing the pump away from the cam lobe so it wasn't making (good) contact, but they are basically the same size as the originals.
Tomorrows plan is remove the lines and blow through with compressor, as suggested on here in another post and by AA bloke. It has no inline filter (will get one ASAP) I also cannot get another pump until Tues/Weds but will order one.
The crap thing is, the lever on the pump that runs off the cam would stiffen up after 10/12 pumps before we stripped and cleaned it, and after that it was fine and seemed to have decent suction/blowing capabilities, but maybe not good enough!
Sorry for the essay, but just wanting to let everyone know the score.
Any help is appreciated!
Do you think it's as simple as the pump being on it's last legs and hasn't the power to draw the fuel far enough through?
Cheers, Liam.
Cheers, Liam.
