i am thinkin about swapping my 1.7 engine in to my 1.4 340
as the 1.7 is rusty and the electrics are knackered
i was just wondering if this will require alot of modification
ie, wiring, fabrication and such like
kev
1.7 conversion?
- volvodspec
this is a direct fit if your 340 1.4 is a mk3 version with the latest model heaterhousing,
you do have to swap the entire engine bay,
- wiring harness
- rear engine mounts
- front engine beam
- exhaust
- coolant hoses and radiator
- renix ignition system
for the best result you can swap the gearbox aswell, the 1700 versions have the 5 speed gearbox standard. the clutch housing can't be swapped, the size is different to a 1400 and the bdp-sensor is mounted differently.
another tiny one, the 1700 model has the intake hose for the air filter housing connected to the front via somekind of plastic nozzle..
since you can use all the 1700 parts, it won't be a hard swap. good luck;)
- wiring harness
- front engine beam
- exhaust
Swap the header tanks too, and save the 1.4 one for a rainy day will save you having to drill the 1.4 one.
volvodspec wrote:this is a direct fit if your 340 1.4 is a mk3 version with the latest model heaterhousing,
- wiring harness
- rear engine mounts - same no need to change
- front engine beam - same no need to change
- exhaust
- coolant hoses and radiator - rad is the same
only thing i needed was the coolant pipes and the down pipe my dad welded the rest of the 1.4 exhaust on lol
i know they are different but the 1.7 exhaust was destroyed with rot
oh and had to re route the fuel lines to the drivers side chassis leg
cheers for all your help
you guys are awesome and so helpful on here unlike driftworks or trampdrift where they just slag you off
kev
kev
