Rear Brake Disc Conversion
How many of you guys have actually done this??
Any particular donars cars to look out for??
Re: Rear Brake Disc Conversion
Do you need cable handbrake or happy enough with just hydraulic??????
Write it in your heart.
The code of the West.
depends what the options are??
Don't know about cable operated h/brake option.
But rally car runs V360 frt discs with iirc early Cooper S calipers.
I'll ask our kid at the weekend what yr they're from as he knows all the details if that's the way you want to go.
Not got ticket on the rally car then dude
Still in bits
only been 6 yrs since it last turned a wheel in anger
- filthyjohn
Could use a dual activation caliper like on a 205 1.9, then you'd have the required mechanical handy-b. Or, possibly make a setup like a mk3 cavalier, where the rear disc has a friction surface on the INSIDE as well, with shoes etc running inside it. Sort of like a drum, with a massive fin around the outside for the caliper to bite on.
- 340GLT
Give me a couple of weeks and i can / will have a conversion kit to allow fitment of rear disks. My kit uses standard 340 cables so its a nice touch. Been on my car for over 2 years with no problems.
340GLT wrote:Give me a couple of weeks and i can / will have a conversion kit to allow fitment of rear disks. My kit uses standard 340 cables so its a nice touch. Been on my car for over 2 years with no problems.
What size disc are you thinking about?
Need some to go under 13's if that's possible.
germ
What about fronts? i need some bigger discs but using same cali's (poss with an extension bracket?)
Volvo 340
1988
1988- 340GLT
My conversion will go under 13's
Fronts i can do aswell i have at least 2options available. both 280mm
- 340GLT
-x-salmon-x-
i would be quite interested in getting a rear disc brake conversion too! how much would you be looking for for it?
look simlar to an 440/ s40 caliper, as for the hub/ disc whats that from?
Jay
Jay
I would also like to know what parts have been used for this...?
