It's dead!
Posted: 10 Jan 2005 05:53 pm
by Tom
The door at the back, I mean!
Even when the catch is up, the door won't budge. Any suggestions?
Posted: 10 Jan 2005 06:29 pm
by 5lab
kick it from the inside
Posted: 10 Jan 2005 07:10 pm
by morgan105
:roll: Does this only happen from the inside? if so the child lock is probably on.
If stuck from both sides then do as slab has mentioned but have an assistant lift the door handle from the outside while you kick from the inside.
:D
Posted: 10 Jan 2005 07:21 pm
by bogbasic
Plenty of WD40.
Posted: 10 Jan 2005 08:34 pm
by Tom
I should have explained that the door opens from the inside only. The external door handle does not seem to work.
Posted: 10 Jan 2005 08:36 pm
by 5lab
oh right, take the inner panel off and re-hook the rods up
Posted: 11 Jan 2005 09:59 pm
by lentinj
Yep, check the rods. Exactly that happened to me, the rod connecting the central locking motor/lock bit sticking out the top to the handle had fallen off so the door handle was stuck in lock (when the door is locked, the inside handle works, the outside doesn't). This was also alot easier to get to than the rest of the door handle mechanism, which is where I first went to look :/
Posted: 12 Jan 2005 12:11 am
by special
tom,
this might be of interest to you
http://www.volvo300mania.com/forum2/vol ... 0-f298.htm
incedently the door still opens and theres still no door rod
:lol: :lol:
Posted: 22 Feb 2005 06:05 pm
by ereg340
I had to get this problem sorted out twice in 2 months . When I bought my 340 the front passenger door would'nt open and I drove around like it until the MOT was looming. I took the door interior panel out and found the part of the handle where the rod connects had shreaded off.
It cost £42 including the replacement door handle and fitting at the garage to put right . Stupidly I did'nt get the lock barrel swopped over .... and a few weeks later the same happened with the drivers door , so for a few weeks entry was via the boot :lol:
Will ereg340
