Fly Wheel Bolts?
germ
Fly Wheel Bolts?
Post by germ »
Does anyone know where i can get some? as my local factors say they don't do them..and i should re-use the old one's with lock tight :shock: iif i can't get them quick enough is it ok just to lock tight and torque them up?
alsoo im right in thinking i need to use volvo fly wheel bolts with my volvo flywheel on the renault engine..due to flywheel/flexplate thickness differnce?
Thanks Very Muchly 340pw :mrgreen:
Volvo 340 Image 1988
Re: Fly Wheel Bolts?
Use the ones for teh flywheel. Re thread lock them and they will be fine. I've never had to replace with new before.
kaos
Post by kaos »
any reson your using the volvo one? the renault one is lighter F7P so should be worth weighing to check difference.
germ
Post by germ »
erm not when im using an F3R with flexplate lol i *suspect* the laguna has a heaveyer flywheel aswell. i guess its worth weighing up..i can try weigh the volvo one, if its of any use?
The clutch is different on the manual version as well so the 300 flywheel is the one to use.
