need diff,360
need diff,360
as title need diff for 1983 360 gls asap,cheers gus
Re: need diff,360
Any 300 dif should bolt up to the box.
Look for the different coloured tags that show ratios-yours should be 3.27/1 most common is orange tag 3.64/1 if I remember.
Plenty in breakers yards I would think if you can't get sorted on here.
Write it in your heart.
The code of the West.
Re: need diff,360
cheers mate,didnt realise they would all fit,so if i got one of a 1.4 or 1.7 it would lower the gearing,as im useing it for hill climbs etc that would be be better,cheers gus
Re: need diff,360
1.4 will give you 3.82/1 so look for one of them.Unless you can find a super early one then 3.91/1
Our kid has a 4.78/1 rare Swedish special but will be 3 figures to buy.Cost him 150
Or alternatively I've got a 4.63/1 Atlas in the shed
Re: need diff,360
whats the atlas? is that in atlas axle?\ and how much you wanting?
Re: need diff,360
thrasher wrote:whats the atlas? is that in atlas axle?\ and how much you wanting?
Aye, as in straight out of a P100 diesel.
They're the 4.6 in a heavy duty casing-5 stud shafts so you'd need some Gp4 shafts.
These axles are the ones loved by the rally lads due to the h/d axle casing and the 4.6 CWP is a favourite for circuit racers.
Gave a ton for it wouldn't take a penny less.
Tek some shortening to fit a V300 baby,baby Atlas
Re: need diff,360
cheers mate,got you,was really looking for something that will go straight in,so i can get it back on the road the now,cheers gus
Re: need diff,360
Look for a 1.4 Diff and bang it on 13's you should notice an improvement off the line
3.27 to a 3.82 is all good for climbing hills.Some 50 profile 13's also help.
- foggyjames
Re: need diff,360
3.82:1 is nice in a NA 360.
I've got a few 3.91:1s, but they're 4 speed...not sure how easy it'd be to make the pinion fit the 5 speed casing.
