Hello,
My car has just failed its MOT because the anti-roll bar is missing! And being on the bottom of the car I didn't notice.
The right hand suspension strut has been replaced with the wrong one that doesn't have a mounting for the anti-roll bar so they've just
left it off.
So has anyone got an anti-roll bar and a right side strut for a 360 I can buy?
Anti-roll bar
- filthyjohn
Re: Anti-roll bar
I have a 340 one spare. You could fit it to the 360 but it'd have to mount in the same way as a 340, with drop links into the wishbone. It was done this way on early 360s too so it wouldn't be a problem. I can include drop links and fitting instruction photos if that helps. In fact, I'll sort some photos of the two different mounting systems so you can see what I'm blithering on about.
- filthyjohn
Re: Anti-roll bar
Coo-el. I'll get some pictars all the same, I can't see much advantage in the late 360 mountings, so it should be as good as OEM.
Re: Anti-roll bar
That would be great thanks.
Re: Anti-roll bar
There's a aftermarket late model 360 swaybar on ebay aus at the moment.
