f7r on throttle bodies
Posted: 27 Apr 2009 06:42 pm
by cindral
Hey guys,
Just a few questions about putting my 340 onto bike carbs.
I have recently installed the f7r into my 340 and am considering fitting some bike carbs on there. i have been offered a set with manifold.
Can someone tell me how they have set them up as they are gravity fed. My mate who had them on his clio said he was running two facet pumps one to send and one to return, and even then he said it was very temperamental and either worked very well or not at all!
I will be using my ally fuel tank, facet pump, and a fuel pressure regulator before the carbs themselves does this setup sound right?
All help would be much appreciated.
Ross
Re: f7r on throttle bodies
Posted: 27 Apr 2009 07:37 pm
by kaos
think you might be wanting a swirl pot as well in there somewhere really
Posted: 28 Apr 2009 02:41 am
by filthyjohn
It should be ok without a swirl pot, a low pressure pump will keep the carbs constantly fed without worrying about fuel starvation. I use a facet 1-4psi electric pump and Filter King fuel pressure regulator supplying 1.5psi. The bike carbs will be good at a simlar pressure. Don't worry about them being gravity fed, bikes go to all sorts of angles when wheelying, so they're always fed fuel under pressure to avoid feed problems.
You shouldn't need a return line to the tank, unless your carbs are from a bike that has one (can't imagine why a carb engine would need a return). One thing to watch out for is that the carbs like to be mounted at the same angle as they would be on the bike. If it's a bit off, it'll mess up the floats. This may explain your buddy's tempramental running.
Hope this helps.
Posted: 28 Apr 2009 09:48 pm
by cindral
Cheers guys for the info. John i think you might be right there! can anyone point me in the right direction for a manifold? i would make one myself but iam having trouble accessing the tools required.
Posted: 28 Apr 2009 09:49 pm
by cindral
filthyjohn wrote:It should be ok without a swirl pot, a low pressure pump will keep the carbs constantly fed without worrying about fuel starvation. I use a facet 1-4psi electric pump and Filter King fuel pressure regulator supplying 1.5psi. The bike carbs will be good at a simlar pressure. Don't worry about them being gravity fed, bikes go to all sorts of angles when wheelying, so they're always fed fuel under pressure to avoid feed problems.
Hope this helps.
John did you drill out the jets at all?
Cheers Ross
Posted: 29 Apr 2009 01:50 am
by filthyjohn
No but mine are Dell'orto car carbs, so I can just buy whatever jets I need. I heard that R1 carbs will accept weber jets, but can't say for certain. What exact carbs were you looking at? Bogg brothers near York make manifolds all day, charge about £175 or a one-off.
As a rule of thumb, get a set from a bike with half the engine size. They rev twice as high so the jetting is in the right ballpark.
Posted: 29 Apr 2009 11:57 am
by cindral
by filthyjohn » 29 Apr 2009 12:50 am
I will be using R1 carbs. I was going to make my own manifold but for a piece of mind i may contact the bogg bros.
Posted: 29 Apr 2009 03:40 pm
by filthyjohn
R1 carbs should be roughly correct, and once set up should net 170-180hp on an F7R I'd have thought.
Posted: 29 Apr 2009 10:54 pm
by cindral
lol, 170-180bhp
omg thats gonna shift! been on phone to bogg bros today got a quote off them! roll on payday! lol
Posted: 30 Apr 2009 11:13 am
by filthyjohn
It certainly will shift. That's some really serious power:weight ratio, but you'll have to be careful with the prop and diff.
Posted: 01 May 2009 05:05 pm
by xtrmjks
filthyjohn wrote:No but mine are Dell'orto car carbs, so I can just buy whatever jets I need. I heard that R1 carbs will accept weber jets, but can't say for certain. What exact carbs were you looking at? Bogg brothers near York make manifolds all day, charge about £175 or a one-off.
Dellorto don't make carbs anymore, still makes parts. I can get hold of any jets for Dellorto's, next day!
You can use weber jets on most bike carbs. No need for return line, as carbs are high flow, not pressure.
Posted: 08 May 2009 06:53 am
by Fuse
Hope this helps.
One situation I can think is carbs+turbo and enough boost and you would need a return line.
That's because you'll need to raise the fuel pressure the same amount there is boost present and if you got 1 bar or more boost, not many carb pumps can give that much of pressure and enough flow, so it's usually EFI pump+fuel pressure controller in those setups.
