1.7 340 bits for f7p conversion.
linkay
Post by linkay »
Hey I have a 340 1.4 dl that I am giving the valver treatment to :) and am in need of a few bits.
So if anyone has:
1.7 bell housing
1.7 front engine mounts + beam
1.7 sump (if im right in thinking this will help the f7p clear the steering rack)
I think that’s all i need for the conversion? Soon find out.
Could you let me know if u have any of these bits as it would be greatly appreciated :)
89(F) 340 DL F7P - Sold :(
Clio 182
kaos
Re: 1.7 340 bits for f7p conversion.
Post by kaos »
a lot more bits required. you wont need the beam if your 1988+
linkay
Post by linkay »
cheers saved me getting another beam, yer think there is a few more bits needed still, think i need the 1.7 rad hoses? not too sure about what else? cheers , Ben
Clio 182
kaos
Post by kaos »
1.7 parts:
sump
engine mounts
bell housing
clutch cable
clutch
rad hoses
alternator mounts
16v parts:
coil pack
map sensor
etc
linkay
Post by linkay »
cheers for the help i have a bit more of an idea of where to go from here now, i don't suppose you know what flywheel i need as the 1.7 bellhousing i have got doesn't fit over the f7p flywheel??
Clio 182
kaos
Post by kaos »
renault 19 1.8 16v flywheel engine desigfnation F7P
Post by 340GLT »
linkay wrote:cheers for the help i have a bit more of an idea of where to go from here now, i don't suppose you know what flywheel i need as the 1.7 bellhousing i have got doesn't fit over the f7p flywheel??
You almost definately have a 1.4 bellhosuing then.
linkay
Post by linkay »
cheers for the help guys, ill have to ring up and have a moan tomorrow then.
1.7 bellhousings seem to be getting pretty rare :cry:
Clio 182
