1.4 and 1.7 bell housings
linkay
Post by linkay »
Im converting a 340 1.4 dl to a 1.8 16v (f7p) lump and got a 1.7 bell housing posted from a specialist volvo breakers, but from what i can tell it looks identical to the 1.4 one? How different looking are they and had anyone got any pics of the 1.7 bell housing so i can see if they have just sent me a 1.4 bell housing as this will not fit over the f7p flywheel and only the top 2 bolt holes line up??? hope someone can help, cheers
Ben
89(F) 340 DL F7P - Sold :(
Clio 182
jpv
Re: 1.4 and 1.7 bell housings
Post by jpv »
I don´t have any pictures here but they are different.
The spigot shaft is longer on the 1.7 because the flywheel is a lot thinner than the 1.4 flywheel. As a result the hole bellhousing and spigot bearing piece are different from the 1.4 one.
You'll need the hole 1.7 bellhousing to fit in the F7...
Post by 340GLT »
If it doesnt fit its the wrong one for sure, the 1.7 one has the flywheel in the very top IIRC the 1.4 one is offset?
kaos
Post by kaos »
theres quite a blatant size difference when you look at them i found. i'll measure up a 1.7's ID tomorrow.
