F7P... Clio or R19?
Jonofdoom
F7P... Clio or R19?
Post by Jonofdoom »
ANOTHER F7P question, sorry:D
Basic one really.. Will the Clio and R19 F7P engines both be an equally simple swap into a 1.7 340?
As far as I can remember from lurking here, they're the same bar some pump or other on teh R19 that needs swapping for a Clio unit, but I thought I'd double check first!
Just started looking for one:D
Re: F7P... Clio or R19?
R19 runs coil pack Ignition?
Jonofdoom
Post by Jonofdoom »
According to someone on retro-renault they both use the dizzy setup.. And all the pumps are the same... "Only the looms, inlet manifold and aux belt set up differs." I don't know where I got that pump thing from:D
Look like I'll be just fine with either!
it might be the megane 16v thats coilpack then?
im not much help am i?
Post by filthyjohn »
Both the same bar the thermostat housing being a little better suited on the 19 one. I've fitted one of each. It's the meganes with dizzyless coil pack ignition.
kaos
Post by kaos »
the pump thing your refering to could be the electronic water pump that runs on after engine switch of, i cant remember if it was in the 19 but it was defo in the clio or the other way round.
Don't think either of mine had any electric water pump thing, though the R19 one had a slightly more complex water hose arrangement, with some sort of heat exchanger sandwich plate on the oil filter.
Jonofdoom
Post by Jonofdoom »
Cheers... Looks like either will do just fine then:D
-x-salmon-x-
Post by -x-salmon-x- »
do people think the second water pump is needed? as i've heard some say that it can damage the heads without it?
Post by 340GLT »
Not needed the clios suffered from a very small rad so they added the auxillary pump, volvo rad 52mm is more than adequete.
-x-salmon-x-
ahh right kool thank you.
340 Nate
Post by 340 Nate »
hmmmm, where bouts is the auxilary pump located?, is it next to the dizzy cap?, only reason i ask is because my volvo had the r19 f7p engine in and now its running a clio f7p with the r19 modified loom?.
I hope this damn thing will run with the 19 loom! :cry:
nathan
Post by 340GLT »
Is that still the loom from lees car mate?
340 Nate
Post by 340 Nate »
yea dude still same loom, are you gonna dish the bad news now? lol.
nathan
Post by 340GLT »
It will run fine..... I have found a proper way of doing the speed sensor now aswell.
