Desperately Needed..Pressure conscious reducing valve
VolvoMalta
Post by VolvoMalta »
the model is a 340 GL 1.4 Petrol 1983... Any idea where I can acquire one as mine is leaking much fluid...email on djx1203@gmail.com thanks
sven360
Re: Desperately Needed..Pressure conscious reducing valve
Post by sven360 »
Rear brake compensator valve is that what you refer to?????
Adjusts rear braking depending on load.
Write it in your heart.
The code of the West.
VolvoMalta
No This is what I'm referring to....It could be named in several ways but you could be right..
Post by 340GLT »
What year and model is your car? As i'm sure the late valves dont look like that...
^^^ hmmm yeah, I was thinking the same......
magnumpi
Post by magnumpi »
volvosneverdie wrote:^^^ hmmm yeah, I was thinking the same......
:lol: 340pw
VolvoMalta
It's a 1983 340 GL 1.4 Petrol :340: (only a couple left here in Malta) which makes it more difficult to find parts for it.
It's the same as the one hereunder...
VolvoMalta
Ok so basically it ended up that all I need are the rubber seals of the Brake Master Cylinder...any one u can suggest to buy from or any other model sharing the same master cylinder ?
sven360
Post by sven360 »
