Prop shaft clamp torque settings
Posted: 04 Aug 2009 03:27 pm
by mrsoundcraft
Hi, Im sure this information is already on here but I cant find it. What is the correct torque setting for the prop shaft bolts on a volvo 340 1.4?
Re: Prop shaft clamp torque settings
Posted: 06 Aug 2009 12:50 am
by mrsoundcraft
Im waiting for a Haynes manual off ebay. Its got to have the specs? As cant get the car running till this is tightened up.
Posted: 06 Aug 2009 05:57 am
by nomead
From the Haynes manual:
Propeller shaft clamp bolts: B14 and B172 - 27 lb ft / 37 Nm
This information could also be found in the Green Books available here on the forum - the one for the manual transmission has the relevant information: Clamp coupling bolts, propeller shaft ... B14, D16, B172 - 37 Nm
Posted: 06 Aug 2009 09:12 pm
by mrsoundcraft
Thanks. I might have the car running by next week
Posted: 08 Aug 2009 03:49 pm
Well done for looking for this information, I've seen so many ruined due to over tightening. Make sure your torque wrench is reasonably accurate, preferably check against someone else's.
Posted: 10 Aug 2009 01:48 am
by mrsoundcraft
After reading some of the stuff about the problems that can result I thought it was for the best, just couldn't find the info when I was going to do it. Hopefully I'll get it on Tuesday, I'll check my wrenches too!
