shocks done
littlered
shocks done
Post by littlered »
well we bit the bullet today and did the shocks!
20 years of roadlife and every single nut and bolt undid,allthough we had to heat the top of the front shock housings to release the top seal,but now i have classic swede blocks,springs,and shocks!
took the car for a spin and WOW it is so much better,flat cornering but not filling dropping hard,fast corners power in and theres no roll at all,to say the least we are very pleased.
booking it in for lazer alignment and grab as much camber out of it as possible,as james greenwood,of greenwood racing developments knows a trick or to about camber and these volvos
a few pics
Re: shocks done
Great work, nice shocks too Dai... where are the adjusters for the fronts out of interest?
Are they new top mounts too??
turnbullj
Re: shocks done
Post by turnbullj »
i jus got some of these aswell been doing the rears today but need some spring compressors for the front, i cant see where u adjust the front ones either or am i just being thick?
88 Volvo 340 DL
55 Fezza Zetec S
littlered
Re: shocks done
Post by littlered »
ther are adjusters
dai please explain how this is done mate as there wasnt any instructions
cheers carlyle
tommysb
Re: shocks done
Post by tommysb »
Shocks look great!
Re: shocks done
If they are the same as the early ones Dai showed me a while back (and I think it's pretty standard for front adjustable inserts) there is a twiddly thing in the main strut top nut.
Most kits come with a tool for twiddling the twiddly thing.
Re: shocks done
Chris is right.
In the bag with teh top nut is little tool (looks like a dome top nut) for truning the adjuster.
To start you need to wind the adjuster fully anti clockwise and then as a start turn it up between 7 and 10 clicks. You cant always feel the clicks so you can go off teh number of each of teh flat sided of teh adjuster you have turned.
littlered
Re: shocks done
Post by littlered »
cheers dai,how much do they adjust,hight,ride comfort etc
we are most deffinatly getting there with the car,what would you recomend now suspension wise bushes?
garth
Re: shocks done
Post by garth »
How much is the full set? Front and Rear?
Fuse
Re: shocks done
Post by Fuse »
Very nice! 8) What brand shocks are those or are those custom job by some manufacturer?
robinxr4i
Re: shocks done
Post by robinxr4i »
Proper job 8)
littlered
Re: shocks done
Post by littlered »
i simply cant tell you what a difference this has made,its like the car was taking all the bumps and contours in the road,but now everything is soo much more damped leaving the car feeling very flat and stable it reminds me of the old mk1 mexico,cant wait to get the new wheels on and full lazer set up with camber.
all in all its awesome.
garth
Re: shocks done
Post by garth »
How much for the full set front and rears?
Re: shocks done
littlered wrote:cheers dai,how much do they adjust,hight,ride comfort etc
They are adjustable for bump and rebound with 40 point adjustment. You will find after a few weeks you might want to turn them up a few extra clicks after they have beded in.
Re: shocks done
garth wrote:How much for the full set front and rears?
£170 for a pair of front adjustables.
£130 for rear adjustables
