Gear or bearing noise (CVT)
Posted: 03 Oct 2009 07:54 pm
Whirrlllll...noise if i drive at steady speed. No noise if I accelerate hard or if I release the throttle at high speed. On steady speeds it's there sometimes.
Sounds like gear noise. I tested it with putting gear to N and revving up until the clutch engages. I can hear it then too.
Did inspect the primary transmission in some way. I put "noise reduction" liquid to the transmission -> no difference. I have had success with this liquid in previous cars with rear end gear noise.
Because the noise is there with revving at neutral it has to be:
1) conical gears at primary transmission
2) Clutch housing rear bearing
3) primary transmission front bearing
Because of the same reason (revving at N) it cannot be:
1) Clutch release bearing
2) Belts
3) Secondary transmission gears
4) Angry owls at the nearby forest
More ideas before I replace the primary tranny for nothing?
2) Belts
