Combined temperature sender / switch (SMITHS)
Looking for a NOS or used working <1982 temperature sender, two terminal type for this type of gauge:
The wiring is fine, I can only guess that either the sender is duff or the sender isn't earthing properly. :?:
Re: Combined temperature sender / switch
Post by MCHUDD »
If you ever manage to find one of these,would you please let me know where you got it.
Mine works but it could work better.
Cheers mark. sm4
Do you know the specs for them guys? VDO do them by spec, so thread size, temp range and temp for the switch cut in. If it already has a part number even easier ;)
EDIT:
This is the linky I wanted
http://tinymicros.com/mediawiki/images/ ... mation.pdf
P22 (17 of 86) <- that'll make sense when you see the page numbering of that pdf
I'm going to look at mine again when I'm near it in just over a week. It's only done 15k, maybe it's corrosion and not earthing fully. Wiring is fine. I'm surprised that a switch would fail with so little use (probably what killed it :lol: )
There's got to be a big stash of these somewhere.
I don't know the spec, but will get part numbers off the one in vehicle when I'm in Glasgow.
I do know the Volvo number though ;)
Just posted the above linky, but finding a VDO from a Volvo number is normally possible. Post up when you find the no, and you'll be able to get a new rather than NOS one ;)
I'm told it's 3285410. For a 1.4 Vario.
Can't find anything quick from that, I'll check the green books though when I get a chance though.
Good luck, because I haven't found anything........yet.
Post by trabitom99 »
Chris_C wrote:Just posted the above linky, but finding a VDO from a Volvo number is normally possible. Post up when you find the no, and you'll be able to get a new rather than NOS one ;)
Bear in mind, those are Smiths' gauges. Don't know if that necessarily makes a difference for the sender though ...
Post by MCHUDD »
Hi all.
Will agree with Tom here.Thay are smiths senders.
Cheers Mark. sm4
Yeah, hadn't thought of that :oops: If one of you has a working one, then we can check it's a 0-180ohm type same as the VDO's though.
We'll find something that works as it should anyway ;)
Re: Combined temperature sender / switch (SMITHS)
Right, in Glasgow and had a look at the sender (after tightening up some very slack tranmission drive belts :oops: )
Smiths Industries 18/2 is stamped on one face of the hex.
TTS 1103/00 on another face.
Conical seat to it and I think M14 x something or other thread.
Found THIS so I'll get on the phone to Cai gauges in Wales in the morning.
macplaxton wrote: THIS
Sounds about right doesn't it :D Fingers crossed
That's good news, let us know how you get on. Except for that South African site I wasn't able to find any source for that sender either with the Volvo number or the Smiths no ... From '84 onwards there are QH senders available, but that won't help you.
Fingers crossed ...
I'll see what I can do tomorrow. Anyone else interested in one?
