Finally Rear Disk brake brackets!!! 340 ONLY!!
Posted: 13 Nov 2009 08:18 pm
by 340GLT
Right i have my Cad package working fine now. And have finished the drawings and got a quote from a CNC machine shop.
For a pair of brackets to suit 239mm Disks. Its £100 Delivered This is brackets made out of 6061 Aircraft grade aluminium all bolts, spacers etc.
The kit will use Ford Sierra Rear Calipers and standard handbrake cables. Due to the handbrake fitment its 340 ONLY at this moment in time. Kit will also include details of what brake disks to use.
There is a possibilty the price will come down if Enough people are interested.
Cheers Adam
Re: Finally Rear Disk brake brackets!!! 340 ONLY!!
Posted: 13 Nov 2009 09:38 pm
by kaos
Intrested,
But which car/source is used for the disc's and pads?
Posted: 13 Nov 2009 09:42 pm
by 340GLT
Well pads are obviously Sierra ones and as said disk details supplied in kit.
Posted: 14 Nov 2009 12:08 am
by kaos
kk, Have we got to drill the disc's it states 9inthe instructions or are they direct fit?
any particular sierra callipers>? i dunno if theyre different?
Posted: 14 Nov 2009 12:55 am
by garth
I personally went for the smaller ones considering I don't think my front ones are as big. With a hydraulic handbrake kit that works, why would you need massive brakes on the back. On the front aye, but as long as there's some modulation and when you pull the wand she works, then job done.
I'm probably wrong in all of the above because I just watched the rugby, and had a few.
Posted: 14 Nov 2009 01:19 am
by mrsoundcraft
Im interested but want a vented upgrade on the front. Would the 340 standard front disks fit on the back?
Posted: 14 Nov 2009 02:56 pm
by Stefan
sign me up for a large set for my daf 66 as i will be using 340 rear hubs on its beam.
Posted: 15 Nov 2009 04:42 pm
by 340GLT
The disks are direct fit on the back however the drum assembly will all need removing and the bearing pressed out to remove the axle. If needs be i can offer this service on an exchange basis.
Front vented upgrade is in the pipeline too.
Posted: 16 Nov 2009 03:44 pm
by Stefan
Put me down for a front set as well then
Posted: 20 Nov 2009 03:49 am
I might well be interested in a set for the 343...which retains the 340 axle. The 360 is going to need something a little more hardcore I think...
Posted: 20 Nov 2009 12:52 pm
by 340GLT
The 360 will prob want the 273mm setup thats going on the grey car.
Posted: 20 Nov 2009 01:40 pm
I more meant I'm not at all sure it's still going to have the right axle to bolt them on to
Posted: 29 Nov 2009 02:17 pm
by Stefan
Any news on these
