Original radio cassette with code?
Olga
Post by Olga »
Hi, anyone got a radio cassette to fit a 1990 1.4 auto 340? I want the same as is in it now, ie the original one... but preferably one that lets me play tapes lol!
Thanks! Olga
Re: Original radio cassette with code?
Post by trabitom99 »
What's the code of the radio, Olga? Is it any of these?
Olga
Post by Olga »
No, afraid not - it's a vc802 radio cassette - there is one on ebay but with no bloody code!!
Olga
Post by Olga »
But would take ANY working volvo radio cassette which is in cosmetically good condition! Olga
As you're on a budget.
Take the old one out, pop it open and see where the belt has gone. Probably just fallen off. Maplin Electronics might have something the right size to replace it.
Or, just use an mp3 player with a cassette adaptor as it doesn't need a motor to turn the spools, just contact with the heads.
That's what my money is on. Broken or stretched drive belt.
If you're not inclined to have a peek inside, don't throw it out.
Olga
Post by Olga »
Brilliant advice - thank you! Yes, very tight budget... got to buy hatch struts, plugs, rotor arm, change oil, check drive belts, buy stuff to fix a big hole in the hatch... so cheap cheap... I'll try that about cassette: it does play but slooooowwwwwwwly...
So you can get replacements from maplins? Thanks :D
Olga wrote: I'll try that about cassette: it does play but slooooowwwwwwwly...
Haaaave yooooooou triiied liiistening tooooooo cassseeeeetees oooooof whaaaalesong?
sounds better the slower you get. :wink:
Olga wrote:So you can get replacements from maplins? Thanks :D
You can, but it really depends on the length. Or perhaps eBay "cassette drive belt" / local radio/television repair shop / CPC Farnell / RS Components / Electronics shop?
As it's playing, it'll be down to being slack.
macplaxton wrote:Or, just use an mp3 player with a cassette adaptor as it doesn't need a motor to turn the spools, just contact with the heads.
Or an mp3 player with an FM transmittor. That way you can pick up the signal using the radio.
I've had mixed results with that mind, I prefer to use a cassette adaptor ...
Do you fancy this one? Not digital or anything. If you don't mind the look I'll test it out, its coming out anyway. Hasn't been used in 10 years. You can have it for the postage and packaging.
Hey, metal tape facility! Dolby! Loudness button ;-)
That was some fine piece of kit in the 80's ...
Olga
Post by Olga »
Ha ha - a very fancy radio indeed, looks much 'taller' than mine? I'll see if I can fix the old one first, then maybe get backto you on your very fine offer Ride_on - thanks everybody! :D
If you don't want it Olga, I'll happily take it off your hands, Rideon!
trabitom99 wrote:If you don't want it Olga, I'll happily take it off your hands, Rideon!
Tom you are developing quite an unhealthy interest in 80's Volvo stereo's ;)
:lol:
8)
