Automatic gearbox
nekto
Automatic gearbox
Post by nekto »
Hello all
Did anybody fit auto gearbox from other models?
I think that gearbox from any redblock could be fitted to B19A?
May be I'm a bit crazy:)
'84 360
shimon340
Re: Automatic gearbox
Post by shimon340 »
I've though about this before but arent sure there is adaquate room behind the bellhousing for a gearbox if it were installed as per the 240, 740 etc.
with some bespoke mounts maybe one could be mounted where the gearbox usually sits at the back? A bespoke gear linkage would also be needed.
regards
S
Enjoy your 300s
Gear linkage would work from a 2/7/9 with some cutting. Your main problem is fitting a completely different rear axle/diff/suspension.
nvdw
Post by nvdw »
Fitting an AT in the back is next to impossible. Where are you going to put the torque converter?
nekto
Post by nekto »
Fitting to the back is not a case for me..
I have some crazy idea about tuning, but don't know when I will do it..
So if it is possible to place gearbox in the front, then it is ok
thanks for your replies!
'84 360
