Carbb?
Joe
Carbb?
Post by Joe »
Hey, i have a volvo 340 1.4 with a weber carb and when i start it it just keeps reving and wont stop, i have had the carb to bits and everything seems fine. Does anybody have any ideas what it is?
Cheers Joe
Roll like its your last time and just let the good times roll
Foook power grow some balls and get commited :)
monka
Re: Carbb?
Post by monka »
choke adjusted properly?
Joe
Re: Carbb?
Post by Joe »
What are you ment to look for i see the rubber plunger thingy and it isnt persihed or anything like that ?
Re: Carbb?
Post by volvodspec »
try again, but this time take the throttle cable linkage away
(disconnect the connector rod between throttle cable and carb with the plastic couplings)
i bet you have a busted throttle cable
Joe
Re: Carbb?
Post by Joe »
Its not that its more likly to be the penumatic choke in side of the carb, how do you know if the diaphragm is working properly?
Re: Carbb?
if the pneumatic choke is faulty it hesitates to start on full choke but will start on 3/4 choke.
all this membrane does is if manifold vacuum is build up, it sucks the leaver and allows the choke plate to open slightly allowing air inside the barrel.
Joe
Re: Carbb?
Post by Joe »
fixed it cheers
