limiter?
Posted: 17 Jan 2010 02:25 am
by kds19
will my 1985 b19e have a rev limiter?
my dad say he revved it to 6250 and got scared lol
i havent tried
just wanted to know
kev :D
Re: limiter?
Posted: 17 Jan 2010 03:39 am
by macplaxton
No idea,
(but I did discover that on a 1985 V240 DL with a B230A engine (Pierburg carb & Bosch distributor) the original Bosch rotor arm had a spring loaded cut out, so when the arm was spinning past a certain speed, it would short out the rotor and act as a rev limiter. Aftermarket rotor arms were just plain conventional items that did not do this. Possibly a useless fact that has no relation to the question anyway! sm6 )
Re: limiter?
Posted: 17 Jan 2010 11:09 am
Maybe... the limiter is in the Renix ignition unit...
It seems some cars have them, some don't - however assuming the B19 is like the B200 the rev limiter will be at 6250rpm so you may have just missed it!
Re: limiter?
Posted: 17 Jan 2010 12:43 pm
Is the B19e on Renix? I thought it was LE and points... but then I've never played with one!
There is a list of which Renix's have limiters in the Renix numbers sticky.
Re: limiter?
Posted: 17 Jan 2010 12:50 pm
No.. certainly not an 84/85 injected car, definitely Renix.
Not sure on the 83 GLTs.. I'd be very surprised if they ran points though!
Re: limiter?
Posted: 18 Jan 2010 02:56 am
Are you sure the year/engine is correct. 85 360s where B200s I thought. Anyway a B19E will have a limiter in the distributor arm I think. From memory it has a large oval shaped one with a weight in it that breaks the circuit at the peak revs, of course it is also likely it has been replaced with a later non-limiting standard arm.
Re: limiter?
Posted: 18 Jan 2010 09:58 am
Yeah he's right - definitely a B19E, admittedly theyre unusual on an 85!
Re: limiter?
Posted: 20 Jan 2010 12:46 am
by Ronnie
No points, no limiter on it either that ever found - but then I never really revved the balls off it. No point, you get more power by changing up
