Power steering
Power steering
Post by MCHUDD »
Hi all you tech guys.
I was wondering if you can convert a 1983 360 GLS to power steering.I have got all the bits
from my 1989 GLT eg pump,resevour,pipe work and steering rack.However the bottom
crank shaft pully is different as it only has two grooves for belts.My 1989 three groove
pully will not bolt streight on.Is there any other one that will do.It would be interesting
to know what you think.
Cheers Mark. sm4
sven360
Re: Power steering
Post by sven360 »
Didn't Corsas have elec PAS pump???????
Could be made to fit I would think.
What's stopping the 3 groove pulley fitting??????????
Write it in your heart.
The code of the West.
jarlidge
Re: Power steering
Post by jarlidge »
as far as i know as long as you have all the parts it should all fit in, as for the pully. i think why you haven't got a 3 slot pully on your 1983 360 is that, they never had power steering for these cars back then. should still bolt all on.
but am sure if am wrong someone else will have the answers.
jeff
Re: Power steering
Pulleys arn't a huge problem for a man with a lathe/mill. If it comes to it, find your local band of model engineers and take a drawing to one with an offer of beer, most can't turn down a metal working task :lol:
Re: Power steering
Does the steering column not also need changed. I also have an 89 power rack (kit) without the steering column. The power rack has a short splined connection, but the manual 87 360 uses a rack with a long T bar shaft as part of it, more shaft less column. Power rack has I think the knuckle joint nearer the rack. I also have a PS exhaust downpipe which I think you might need for the power rack with its different knuckle joint position. Of course the GLT may also have it.
What is different about the B19 to the B200 that means the pullies are different? I will have a spare B200 after I get this turbo in. You can have the crank timing gear if necessary, but I don't know if that is what the problem is. edit doh you also have this.
Sounds like an excuse for a visit and I have my beady eyes on a few parts, still a bit cold for knuckle damaging removals though.
Re: Power steering
Post by trabitom99 »
Ride_on wrote:Does the steering column not also need changed. I also have an 89 power rack (kit) without the steering column. The power rack has a short splined connection, but the manual 87 360 uses a rack with a long T bar shaft as part of it, more shaft less column. Power rack has I think the knuckle joint nearer the rack. I also have a PS exhaust downpipe which I think you might need for the power rack with its different knuckle joint position. Of course the GLT may also have it.
+1 to that, the lower part of the steering column is different, and the downpipe on PAS cars has a different "kink" in it ...
Good luck with the conversion, keep us updated! It might be interesting for me too one day, for the DLS ...
Re: Power steering
I'd hazard a guess that a 3 groove pulley from a car with PAS would bolt on 'just like that' :D
mat_91
Re: Power steering
Post by mat_91 »
i know this may throu a spanner in the works but as by the sounds of things
wy not just fit an electric pas out of a corsa ive heard got things from them
well all lot of escort rally boys use them i my self am thinking about it
Re: Power steering
Good thing with using the Volvo PAS kit though is that you'll get a slightly quicker rack, less turns from lock to lock
Re: Power steering
Post by MCHUDD »
Hi everyone.
Thanks for the replys. I will let you know how things go.
Cheers Mark. :360:
Re: Power steering
Hmm actually I've just re-read this... are the pulleys different then Mark?
Re: Power steering
Post by MCHUDD »
Yes. Thay are a different design altogether.I wonder,is it possible to weld a similer
sized pully onto the two pully one to make it a three groove pully?
Thoughts welcome.I have a spare pump with the same size pully.
Cheers Mark. sm4
turnbullj
Re: Power steering
Post by turnbullj »
im very interested in this im wanting to put a quick rack or power steering on my 340 1.4 whats the easiest way to go about it?
thanks James
88 Volvo 340 DL
55 Fezza Zetec S
Re: Power steering
Post by volvodspec »
yeah i can remember something about B19 crankshaftpulleys have different mounting than B200, but not 100% sure!
welding another pulley onto it could make it a bit rough on balancing, a decent machine shop can manufacture a 3groove pulley with an hours work. it doesn't have to be CNC'd so that keeps costs low, you can even consider aluminium while you're at it :wink:
Re: Power steering
Just a thought... will a pulley from a 200 series fit? Ie. B21/23 engined cars?
