engine tuning questions??
kds19
Post by kds19 »
right i have a b19e (85)
and i want more power and higher revs.
what can i do without changing the engine?
16v head or a lumpy cam?
if so which head? from what car?
which cam? from what car?
will i need to change the injection system?
if so to what?
aftermarket or oem ecu?
also if i fit a 2.3na what do i need ie ecu? or what?
85 360 GLT drift beast
clutch kicks ahoy!!!!
sven360
Re: engine tuning questions??
Post by sven360 »
B19 will safely make 137 @wheels.
Well, leastwise that's what mine made last time on the rollers.In my view that's as good as a clubman spec pinto.You just got to work harder than the Ford boys.
Find a good headman and free those gasses.
4 branch would help but mine runs stock manifold.
Lighten and balance flywheel and some 45's will help.Any decent cam company will custom grind a shaft for your chosen duration.Vernier will help dial it in.The one on ours is Ford BDA.
Bottom end is pretty resilient but not sure how thick the rods are.If they're not 13mm they sound like the ones you need.
Surprising how well a blueprinted motor will go,whilst still giving drivability,longevity..........
Write it in your heart.
The code of the West.
sven360
Post by sven360 »
There's some guff here about porting and Volvo rods.....
http://www.turbosport.co.uk/showthread. ... ross-Pinto
kds19
Post by kds19 »
thanks for the help but i cant really afford a race spec build as im only 19 and an apprentice lol
i would just like some info on things i can do cheap and easily that will help a bit
im not expecting 9.000.000 bhp or anything i would just like a bit more power and a bit more revs
using preferably scrap yard parts, bits from other cars, etc
but quite cheap
i can spend a bit on certain things ie getting it set up or what ever
i have a set on dhla twin 40s sitting would it be worth putting them on?
i have read about k cams and h cams where can i find these? 740 of some sort maybe?
lightening and balencing of the fly wheel will be happening at some point
but im just curious what i can do for a bit cheaper
also will a 2.3 clutch fit on my car?
is there anything i can do to get 16v head to fit?
thanks
kev
sven360
Post by sven360 »
Treat the motor to Payne gaskets.
L+B rods and pistons,port the head,fit a cam,bolt on gobblers and smile.
Easy.peasy,lemon squeezy :lol:
kds19
Post by kds19 »
in english please?? (i have no idea what you just said lol) :lol: :lol:
sven360
Post by sven360 »
Translation from Geordie to Jockanese.
Buy a full engine gasket set-make sure they are Payne brand sometimes marketed as Halls gaskets.They are the best.
Whip motor out.Remove rods and pistons,check bearings.
Weigh rods and pistons.As a start find lightest and dremel the other 3 to as close to same weight as possible.
Take the head and measure inlet and exhaust manifolds,match head to the sizes ofthe manifolds.Remove old cam fit one of your choice.
When you're porting the head try and get someone who's done that sort of work before to do it or atleast supervise.
Fit new cam belt.
Attach Dellorto's to engine.
Fit back in car.Relax.
See.Easy.peasy.lemon squeezy.
I suppose it depends on application, but I do like Victor Reinz gaskets.
kds19
Post by kds19 »
do you know what cam is in my car as standard?
and what oem cam i could get to improve it?
this is helping alot!!!! :D :D :D :D :D
thanks
sorry for all the questions i just dont really know much about what to do
and i really wnat to learn
built not bought ftw!!! :lol:
sven360
Post by sven360 »
That'll be Payen gasket set and not payne. :roll:
Old age setting in. :oops:
Victor Reinz certainly do make a lot of gaskets, but all I know is, the engine reconditioners/performance builders will only use Payen up our way.
kds19
Post by kds19 »
if i was to put a 2.3 engine in what do i do?
2.3 is a simple bolt in job.
As funds are tight personaly all I would do is remove teh fuel injection. Fit 240 dizzy and ignition modul for no rev limiter and adjustablility. Get a manifold for twin webber/selex or dellorto carbs. Use a 240 GLT K or H cam and combine that with a well made exhaust system.
That will give you enought to smile about.
Oh and for gaskets use genuine volvo they work the best.
I have to disagree about carbs... it's simple but it's not cheap, not by a long shot. Especially when you already have fuel injection, with high pressure fuel pump and lines.
My money would go on aftermarket engine management such as Megasquirt and bolting on a turbo and 940 exhaust manifold, 13c turbo and custom exhaust. That lot should cost you sub £600 and give you close to 200bhp at 10psi. Carbs might get you 150-160bhp, but much less torque, cost a fair amount and will still also need a rolling road setup.
However, if it was a GLS do what Dai says :D
kds19
Post by kds19 »
well the rolling road tune i can get cheap either way. :D
how much is megasquirt and is it hard to fit?
kev
