'82 343 1.4 No spark.
bob04917
Post by bob04917 » 07 Mar 2010 11:58 pm
Hi folks,
I'm trying to start my 343 and all she does is crank. She last started up about three weeks ago.
It was tuned up last Spring; plugs, points, condensor, wires and coil. I've tested for spark at the plug wires and also at the wire coming out of the coil and there's no spark.
Do the coils go bad this quickly? I wouldn't think so.
Is there some sort of anti theft type thingy in the ignition circuit that may have gone bad?
Any ideas? Please, help.
Thanks for any help or advise.
-- Bob
"We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm." -George Orwell
http://www.dafclubofamerica.org
http://dafclubamerica.proboards.com/index.cgi?
Re: '82 343 1.4 No spark.
Post by macplaxton » 08 Mar 2010 12:06 am
Have you got any power going to the coil?
bob04917
Post by bob04917 » 08 Mar 2010 12:41 am
Rich,
Test light from neg post on coil to ground with ignition key in on position?
Thanks
Post by macplaxton » 08 Mar 2010 01:18 am
Duff condensor?
Post by MCHUDD » 10 Mar 2010 11:19 am
There is an engine emobilizer on mine from new.It is wired to the coil.
The switch is in the centre consol,just above the gear lever.If the switch
is not at the on position,the car will not start.
Don't know if you have one or not. Hope this helps.
Cheers Mark. sm4
bob04917
Post by bob04917 » 03 Apr 2010 10:23 pm
Thanks to all for the tips. I changed the plugs (NGK's) up a heat range and she started right up.
The old plugs, also NGK's are about a year old and were black. I guess she was running rich.
Now she seems to be bucking a bit when I accelerate and the pedal is, say, half way depressed. Power piston in the carb?
Anybody have the same experience? Maybe a new air filter? It looks a bit dingy and I can't find a replacement here.
It's a Mann C3051/1; anyone have any part numbers out there?
Again, thanks for all the help, it's most appreciated. :D
Bob
Post by macplaxton » 04 Apr 2010 12:11 pm
Yo Bob,
Mann air filter C3051/1 is current:
Although UFI don't list it directly, here's the nearest from them:
Here's the UFI interchange list:
  • FORD 5005530
    GENERAL MOTORS 93152738
    RENAULT 7701348248
    AC DELCO PC453
    ALCO MD390
    BOSCH 1 457 432 132
    BOSCH 9 457 234 500
    BOSCH 1 457 429 925
    CHAMPION W146
    CLEAN FILTERS MA450
    COOPERS AG272
    CROSLAND 723
    DELPHI AF0082
    DONIT 41.30.34
    FAPOFIL AP142
    FIAAM FL6530
    FILTRON AR244
    FISPA FAC418
    FRAM CA4291
    GIESSE FILTRI AH878
    KNECHT-MAHLE LX38
    M-FILTER MA6692
    MANN+HUMMEL C3051
    MECAFILTER EL1927
    MIKROFILT 11.0684
    MOTAQUIP VFA189
    MOTORCRAFT EFA244
    PBR AI3141
    POCKET FILTER ANF0342
    PURFLUX A445
    PUROLATOR A57091
    SOFIMA S 2430 A
    SOPARIS (OLD REF.) FPA3158
    TARGA SERVICE 50.032.159
    TECALEMIT B201
    TECNECO AR342
    TECNOCAR A342
    TEHO FILTER ILM237
    TJ B201
    UNICO FILTER AE2953
    UNIPART GFE2123
    WIX EUROPE WA6427
bob04917 wrote:It looks a bit dingy and I can't find a replacement here.
Not been looking hard enough Bobby boy. Ask Super Hans about NAPA air filter FIL 2077. Looks about the right size to me. Application list is HERE if it helps.
bob04917
Post by bob04917 » 04 Apr 2010 03:18 pm
Rich, you are the Man! Thanks so much!
John thought it might be the ethanol blend we have here, but I'm not so sure.
BTW, Fram CA3793 is also listed for the 300 series and others:
RENAULT FUEGO 1.6L - GTL, R1361, 54mm high
1991 VOLVO 300 1.7L - B1, to 10/91
1990 VOLVO 300 1.7L - B1
1989 VOLVO 300 1.7L - B1
1988 VOLVO 300 1.7L - B1
1987 VOLVO 300 1.7L - B1
1986 VOLVO 300 1.7L - B1
1985 VOLVO 300 1.7L - B1
1985 OLDSMOBILE NINETY-EIGHT 3.0L V6 CARB - All
1985 BUICK ELECTRA 3.0L V6 CARB - All
1984 VOLVO 300 1.4L - B14, B14E, to 4/84
1983 VOLVO 300 1.4L - B14, B14E
1982 VOLVO 300 1.4L - B14, B14E
1981 VOLVO 300 1.4L - B14, B14E
1980 RENAULT FUEGO 1.4L - TL, R1360
