Thank you from your answers, I think that renix wheel is usable after all.
Those are teeth counts in that image I posted, but those are default values, I have not yet set it.
I have been soldering wires to connector, what a pain job to do, wires are too thick or something
I will use batch fire that has 2 injectors firing at time, 2 squirts per revolution. Still I'm not quite sure how it works, need to learn more from this, but good thing is that software does pretty much everything, I need to set just few paramaters.
Injection time is taken from rpm signal, ecu does some calcultations of course, I don't know exactly what calculations, but I trust it to knows what it is doing, lol.
This ignition thing is very difficult for me to understand as I need to start learning from 0, but slowly I'm getting there.
So I think I need to put 44 into first box 'wheel decoder base teeth', then I need to set number of teeths from missing holes to tdc, or then not. Hmm, I need to think this little bit more, there is probably some boxes that are not needed to use.
However, I ended up with this, maybe right?:
I can get 36-1 wheel for 20 euros from local ford dealership so it is not very expensive. I think that I will use it at some point, so I can get 4 coils ignition.
That takes over a year however
