Brake Light Acting Strange?
Justin
Post by Justin »
When I brake my nearside brake light is very dim and when my lights are turned on it actually goes out when braking?
1988 340 1.4 DL
Re: Brake Light Acting Strange?
Most likely an earthing problem. Check and clean your earths!
Justin
Post by Justin »
Where are they?
1988 340 1.4 DL
Rear light cluster earths, very typical
Justin
Post by Justin »
I havent a clue where to find the earth, I'll check my Haynes manual...
1988 340 1.4 DL
Check this out:
http://www.volvo300mania.com/forum-uk/v ... =39&t=4384
You probably don't have to go to the lengths Chris did by running new earths, but a good clean of them should sort it.
Justin
Post by Justin »
Miraculously I replaced the number plate bulb that was dead and swapped the connections around on the brake light that wasnt working and voila, the entire rear lighting system works.
Just out of curiosity where are the rear light cluster earths?
1988 340 1.4 DL
It's the aluminium looking strip that all the bulb holders try to rub against. Normally as a temp solution some contact cleaner on both the copper and the ally sorts it out for 12months or so.
I'll try and sort out the pictures on that thread in the next few days
CBA
Post by CBA »
sometimes just disturbing the earth strip will scrape off some oxidised aluminium and restore good contact... ensure your lights aren't flickering over each bump.
